Whats up everyone? Got some pics to share with you, as well as some questions about some wiring!
So my 83 ZX has been through a lot these past few years. Initially I swapped in a T3/T4 E , along with a few other goodies, and was going the megasquirt route. Eventually lost interest, and decided to drop in a 350. I purchased two long blocks from a guy who worked on base, and put new gaskets on the cleaner one. I got deployed shortly after that, and when I got home, I found a good deal on a decent setup.
GM crate motor
Trick Flow 23 degree aluminum heads
Scorpion 1.5 anodized roller rockers
Edelbrock performer RPM intake
Holley 3310 vacuum carb 750cfm
Comp Cams 268XE cam/lifters
MSD pro billet distributor
MSD 6AL box
MSD plugwires
Rebuilt TH350
and a Hughes 22-2500 stall converter.
(pics are attached)
First question is as follows,
MSD 6AL , from looking at a couple wiring diagrams, there seem to be a couple different options for my IGN source. I think I'll go with the hot wire to the old IGN coil. Does this make sense to anyone other than me? haha.
Secondly,
Should it be a problem if I modify the original alternator harness to fit the GM alternator? It seems simple enough, and that is what I plan on doing.
Finally,
If you look at one of the pictures, you will see I am using an engine driven fan. There is not a lot of room , so I will not be using a shroud. Will a short distance between the radiator and the fan eliminate the need for a shroud? I know it would probably be better to have a shroud, but this vehicle is going to be used in the northeast, and it doesn't exactly get over 100 here
Thanks for reading guys, any help would be awesome! This thing is almost done!
Shawn
