42
Everything posted by 74_5.0L_Z
I don't mean to dampen the excitement about these kits, but you cannot use the 5.0 mustang shorties without puuting the engine too far forward. The T5 shifter will not come out of the factory shifter hole in the body or console. I tried. With the engine as for back (header flange against the fire wall, and engine as low as I dared) the shifter was too far forward. I ended up using block-hugger headers, and slid the engine 2 inches further back. The rubber mount on the tranny is 4" behind the factory transmission body mount.
I have the 3.545:1 ratio in my 5.0 / T5 powered Z. I really like this combination with 24.7 in tall rear tires. I had 3.7 gears in the car when I first put it on the road. I changed them after 2 weeks of driving. I would like to try 3.36 gears but R200s with that ratio are hard to find. Currently, 75 miles/Hr in fifth gear is 2700 rpms. The car is a pleasure to drive.
I have built several carbureted 302. My experience says don't over-carb. I was most happy with Holley 600 double-pumper. I later tried a 750 and a 700. The engine was much more crisp with the 600 DP. So, If it me, I'd go with a 600 or 650.
The reason that I chose to build a V8 zcar was the ease with which a high horsepower to weight ratio can be achieved. It is not necessary to build an engine that is on the verge of self-destruction in order to have a very fast car. I have a bone stock 5.0L mustang engine in my car. The car has been a daily driver for nearly a year, has seen ~ 40 passes on the drag strip. I intend to auto-X the car this weekend. Although the car is not as fast as some of the more modified cars on this site, my Z is faster than most vettes, WS6 Trans Ams, etc... The car gets ~20mpg, and I have had no reliabilty problems.
The Neapco part number of the adapter is 2-2-899-1
OK, I'm gonna try rear disks
74_5.0L_Z replied to Dan Baldwin's topic in Brakes, Wheels, Suspension and Chassis
I just finished mounting 1985 maxima front rotors and Outlaw 2800 series (1.38" piston) calipers on the rear of mine. They work great. I had to have custom plates made to mount the caliper. Here is a break-down of the costs: calipers (2) * 125.00 = 250.00 Mike(scca) rotors (2) * 25.00 = 50.00 napa brackets (2) * 60.00 = 120.00 custom hoses, misc. 50.00 afco pads 1 set 60.00 Mike scca This may seem excessive but was well worth it. Before the mod, the rears were worthless. Now the rears are extremely effective. -
I have converted my front brakes to Mike Gibson's(scca) stage II set-up (11.5" x .81" thick vented rotor and Outlaw 4-piston(1.75 in)calipers. I am in the process of upgrading the rear brakes as follows: 1985 maxima fron rotors 10.75" x 0.81" vented Outlaw 2800 series 4 piston calipers (1.38") Custom mounting bracket My questions are: 1. Can I use the master cylinder from a 1974 260Z (does the rear side move enough fluid)? 2. If I use the later 280ZX master cylinder, should I also use the later brake booster? I have a later booster(it's huge compared to the 260 unit. Will the 280ZX booster supply too much assist? Thanks, Dan
As I see it, you have a few options. 1. You can sell the engine and try to find another. 2. You can install the engine, work out the bugs(fuel delivery, electrical, etc..) and later rebuild it with different pistons and heads. Good Luck, Dan
The heads could definitely benefit from porting, especially on the exhaust side. That being said, I would remove the head before attempting this. There is no way that you can prevent particles from getting in the engine if you perform the porting with the heads installed. I am contemplating getting some aluminum heads for mine (1100.00) or having a guy I know at a local port and refurbish my stock heads. He has a great machine for porting that allows him to match the ports to each other. He says he'll do the whole jobs ,including new springs, for $300.00. These heads will outperform the high milage stock heads that I have, but will not perform like the Edelbrock or TFS aluminum heads. It all comes down to this, "How fast you can go is directly proportional to how much you spend." (and I'm poor) See Ya, Dan
I have been using the stock cluth and pressure plate with a hydraulic throw-out bearing. The clutch and pressure plate have given me no troubles. The car has been driven 70 miles / day for 9 months and has ~ 40 passes at the strip. The engine is nearly stock and I am using street tires(no slicks). I average high 1.8 to low 1.9 60' times. I have never had any trouble with clutch slippage. The weak link will be the transmission and not the clutch. Dan
I am using a harness from a 1993 5.0L mustang on my 1989 5.0L engine(the 1989 harness was damaged while trying to extract it from the twisted wreckage of the donor car). I have had no problems. The later harness is the same as the 1989 except for some of the relays. Dan
The factory gauges have a variable resistor (the dimmer switch) in their path to ground. If you didn't use the ground attachments from the factory gauges then the dimmer switch will not affect the gauges. Good Luck, Dan
255/50/16 on an unflared car???
74_5.0L_Z replied to Ray's topic in Brakes, Wheels, Suspension and Chassis
I am using the same rims front and back 15x8 w/5 in backspacing. I have 245/50/15 on back and 225/50/15 on front. I have coil-overs on all four corners. (10 in 200# on back and 12 in 175# on front. The 245/50/15 will fit on the front( I wasn't sure when I ordered tires so I got 225s). I still have OEM rubber isolators above springs. This is not a problem on back but on the front I only have ~2 inches of shhock travel. I plan to get camber plates for the front. What it boils to is get 1? x 8 rims with a 5 to 5.5 in backspacing. -
I have 245/50/15 Dunlop SP8000s mounted on Centerline 15x8 inch rims with a 5 inch backspacing. I am running the coil-overs. The tires barely fit within the stock rear wheelwells. I have less than 1/8" clearance on the inside between the weld-on spring perch and tire. If the spring perch was relocated above the tire (8 inch 350 lb/in springs) ,and wheels with 5.5 inches of backspacing were used then maybe the 255 might fit. Good Luck, Dan -
The late model 5.0 mustang pan will work if the engine is in the right position. My engine is placed such that the front sump is just behind the crossmember. I did have to relocate the front sump drain plug to the bottom instead of the front of the sump. I have about 1/8" clearance between the pan and the crossmember. I also have about 1/8" clearance between the upper intake and the hood latch.
The Tilton set-up that I referred to doesn't use a slave cylinder. A hydraulic throw-out bearing uses a piston built-in to the bearing to actuate the clutch. With this set-up, there is no fork. A hydraulic line goes to the bearing from the master cylinder. As for the wiring harness, I used the stock harness. It essentially stands alone. Just mount the relays, supply power and ground. I also used the Ford starter relay. I only used the engine harness, and the extension that goes to the HEGOs, and VSS. If you don't have the HEGO's then buy the Ford Motorsport relay kit that contains them. It includes a new fuel pump relay, WAC relay, ECU power relay, TAB, TAD, 2 HEGOs, and EVR valve. If these terms are not familiar, then get the EEC-IV book by Charles Probst. It was one of the most valuable tools for understanding how this system works. The book also comes with great wiring diagrams. Be sure to use a 1991-1993 starter. They use a factory mini-starter. The earlier starter(1989) is much larger, and interfered with my headers (Dynomax block-huggers). Good Luck, Dan
Regarding the pedals, keep the stock ones. The Tilton master cylinder is a direst bolt on (just change or modify the clevis). For the gas pedal I calculated the mechanical advantage ratio of the stock mustang pedal, then I cut the top of the datsun pedal to achieve same ratio. I then hammered top of datsun pedal flat to approximate 1/8" and drilled a hole to accept ford throttle cable. Sounds cheap but has worked perfectly for 9 months. Another option would be to get an aftermarket throttle cable(LOKAR). For the emmission, get rid of the air pump. Make sure that you plug the hole in the back of the head. Keep the EGR. At part throttle, the computer calculated air fuel based on a certain portion of Inert mixture, and also increses the timing. If the EGR is removed the result will be a lean mixture and possible detonation. Beside the EGR is only active at part throttle cruise, and increases gas milage and reduces emissions. I don't know what you plan to use for a fuel pump. I am using an MSD (P/N 2225) inline pump. It's rated at 43 GPH at 39 psi(more than twice the capacity of the factory 5.0 pump. It also only costs 110.00.
I have a 5.0L and 5 speed in my 1974 260. I use a Tilton hydraulic throw out bearing and clutch master cylinder. The clutch works great. Here is the post that I made last year regarding the clutch "I am using the Tilton hydraulic throw-out bearing in my 5.0 / T5 Ford powered 260Z. The pedal action is very smooth and as light as the factory Z clutch. I am using the Tilton 74-875U universal master cylinder to operate the clutch. The master cylinder has a 7/8" bore, and bolts directly to the firewall using the factory studs. The clutch disengages about 1.5 inches above the floor, but is not bothersome. I have only been driving the car for about 2 weeks but so far I really like the clutch. The part numbers for the Ford T5 setup are 61-601 for the bearing itself, and 61-612 for the adapter. The adapter replaces the input bearing retainer, and the bearing screws onto the adapter. The adapter also provides much sturdier support of the input bearing than the stock T5 unit. Finally, the Tilton master cylinder, hydraulic throw-out bearing, adapter, and all necessary hardware cost me 423.00 from J&J racing." I have used the clutch now for 9 months (70 miles/day) without any problems. Good luck, Dan
I would suspect that you have a short elsewhere in the system. To test this, disconnect the wiring to the ammeter and clock, and then disconnect the negative battery cable. Then use a VOM between the cable and negative terminal of the battery. With everything off, key off, and clock disconnected the current should be zero. If the current is not zero then you have a short. A good way to isolate the short is to remove all the fuses, and put them back in one at a time while watching the VOM. When you see current then you have found the wiring leg containing the short. Good Luck, Dan
My 260 with a bone stock 5.0 / T-5 runs 13.40 at 102.66. The engine probably has 150,000 miles, and runs flawlessly. The car is not set up as a drag racer and still gets 1.86 sec 60 ' times. Good Luck, Dan
room for passenger side mount Vortech in 240Z???
74_5.0L_Z replied to a topic in Ford V8Z Tech Board
It should fit with no problem. The main concern will be to get it far enough back and down. I have a stock EFI 5.0 and T-5 in mine. I would like to use a supercharger, and I know it will fit. Send me an e-mail address and I'll send you some pictures. Dan -
Pete, You are old.
Dr. Graham, I am using the 1993 harness because the 1989 harness that came with my engine had been butchered, and I found a complete pristine 1993 harness for $50.00. I am using the 1989 computer. I installed the computer in the glove box. It fits perfectly( cut a hole in the right rear of the box for the connector). As for the speedometer, I regret to say that I have been driving for six months without. I have researched the issue though. Most speedometer shops can make a custom cable that is datsun onn one end and ford on the other. The dash is extremely light, and you would be hard pressed to make one that is lighter. I have replaced my gauges with Autometer Sport-Comp units. The 5" monster tach fits perfectly in place of the stock unit, and the 2-5/8" oil, temp, fuel gauges fit perfectly in the three center holes. Good Luck, Dan McGrath
Dr. Graham, I have installed the 5.0 mustang engine and T-5 transmission in my 74 260. The wiring for the engine, and computer is completely independent of the datsun wiring. I used the wiring harness out of a 1993 mustang. The engine and computer harness from that year is easily separable from the rest of the mustang harness. I am using the factory 260 harness for lights, etc... Make certain that you acquire the proper computer for the transmission set-up. You cannot use an auto tranny computer with a stick. Also make sure you get the harness that goes to HEGOs, and that you get all the relays (fuel pump, WAC, ...) Good Luck Dan McGrath
Just got my 88 5.0 mustang, next the conversion!!!
For my 5.0 Z I used the stock datsun fuel pump wiring. I clipped from the datsun harness and attached it to the fuel pump relay that was part of the ford wiring harness. The computer controls the pump. For a pump, I used the MSD inline EFI fuel pump. The MSD pump is inexpensive (109.00), fairly quiet, flows 43 gph @ 39psi, and has been reliable(The car has been my daily driver for 6 months.) Good Luck, Dan
