Floorless240z
Floorless240z last won the day on November 7 2018
Floorless240z had the most liked content!
About Floorless240z
- Birthday 05/08/1985
Contact Methods
AIM
Nerdigger
Website URL
http://www.buffalomotorworks.com
Gender
Male
Location
Buffalo, NY
Recent Profile Visitors
Floorless240z's Achievements
From two '73 240z parts cars: Some things are doubles (gauges mostly). Round 2 has a dark background in photos. Please specify. You can text me at 716-7two5-5366 if preferred. Prices do not include shipping. Coming from Buffalo, NY. Pics in reverse order of text for some reason Everything "ran when parked" fuel/amp gauge +/-60 amp $50 temp/oil gauge $50 Radio - sold panel with defrost and choke indicator light $30 windshield wiper/turn light stalk $40 SOLD short pigtail fuse box w/ cover, damaged. $45 door handle x2 $25 rear view mirror nice $70 SOLD speedo w/74k $45 tach $45 fuel door with hinge $35 Round 2 (parts with dark background) Fuel/amp gauge $60 temp/oil gauge $55 Speedo w/74k $50 Tach $50 Clock, has blemish at 6 o'clock $100 quarter glass w bad weatherstripping $45 +ship each hood inspection lid cover $25 +ship each rear view mirror, not as nice $55 interior light $10
Looking to sell series 1 240z carburetor setup, e46 intake manifold and 4 screw SU carbs w linkage, that indicates they came from a series 1 240z 1970-71. Ran when parked but they've been on the shelf for some years. $295 +ship without air cleaner. Includes everything shown (besides air cleaner piece). Have PayPal and Venmo Available for pickup in Buffalo, NY
This car was sold at Niagara Falls Datsun in 1973. Manual transmission. In the 70's the car was painted red, the g nose and flares were added at that time as well. The g nose is said by Datsun to add 13mph to the top speed of the vehicle, though I've never tested that heh. My uncle bought the car in 1982, the previous owner was a friend of my father's. My uncle had a welder cut out any rust in the floors and put in new metal, he said the car wasn't too bad when he got it. Still have the original warranty booklet, owners manual and service manual, and it looks like an extended warranty was purchased for it back then. In the early 2000's my uncle pulled the motor and had a reputable shop rebuild the head and block. He only drove it a few hundred miles a year as it's one of 5 cars for him. Probably only 5k miles on rebuild. I have his receipts from the engine builder: valve job, mill head, disassemble block, re-hone, new rings, deck block, etc. Also have receipts from Motorsport Auto (now The Z Store) for: crank seals, centerforce clutch w clutch kit, cam oiler tube, headgasket, steering rack boots, rear shoes, wheel cylinder, strut bars front & back, "How to Rebuild Your Nissan OHC Engine" book, urethane steering rack bushings, urethane steering coupler, dual Weber carburetor kit, adjustable fuel pressure regulator, etc etc. From Victoria British: piston ring set, timing chain/set, rear trans oil seal, clutch master & slave, reverse switch, front brake hoses, brake cylinder, etc. Receipts from the local dealer for assorted hardware. Other miscellaneous receipts. I bought the car 3 years ago, though I'd had it for a bit longer than that. I'm 33 and this is my 4th 240z in the past 17 years. I replaced the emergency brake cable, upper and lower radiator hose, heater hoses, any other coolant and fuel lines that looked ready. I eliminated the vapor expansion tank, (car now has no smell when driving with the windows up) vented the filler neck to the top of the tank, new grommets where needed, thermostat, rear brake hoses, hard lines from hoses to wheel cylinders, wheel bearings & seals in back, stub axle nuts, spindle pin kit, just changed the oil 8/10/18 with the blue oem filter, full synthetic 10w30 and Lucas Oil TB Zinc-Plus zinc additive, poly rear control arm bushing set, Ground Control coilovers 200lb Eibach springs and Tokico Illuminas in back, probably some other stuff I'm forgetting. The paint is older, single stage, up close you can see spider webbing in spots, but it looks pretty good for what it is. The paint is peeling a bit behind the license plate, but that's hidden by the plate. Fiberglass hood with holes from hood pins, fit isn't great. 2.5" exhaust, new Vibrant stainless steel muffler last year. No sway bars, I have a stock front one I can include but it needs to be re-mounted. I also have a new hatch seal I will include. Car has original numbers matching motor, only vin plate that doesn't match is the dash as my uncle replaced it in the past with an uncracked one. I do have a pair of round top SU carburetors and manifold that were on the car prior to the Webers (preferable to the Hitachi flat top carbs that came in 1973). The SU's be included in sale if desired. High-res photos can be seen here https://drive.google.com/open?id=1MB4uz0krSWH7IwoCoOew3twWpWb4npjs Clean New York State title in my name NEW PRICE $10,500 obo (716) 7two5-5366 Call or text
This came in a 240z I got a few years ago, I parted the car out as a friend of a friend wanted something for an lsx swap and my uncle has been trying to sell me his 240z for ages. The z I bought from my uncle has a rebuilt numbers matching original motor so I’m not changing it. This L28 came from a 280z and is supposedly built. Unsure what it has, could be just a cam, I wasn’t the one who put it together. N42 block, N47 head. Turns by hand. Remanufactured starter. Intake and exhaust manifolds were on until I just removed them, it wasn’t sitting exposed. L28’s originally came in 280z’s but they can be used in 240z’s with carbs, an electric fuel pump, and ignition control (I have a Crane kit and a GM unit people often use available). $675 6-1 header available separately $195. Round top SU carb complete setup available extra with motor. Located in Buffalo, NY, I’d drive across the border in exchange for a bottle of vodka from the duty free heh Text or call 716-7two5-5366
