All of the sites that I have seen with actual flow #s, come up with nearly the same flow on the 25 and 26 heads. The ports are almost identical if you look at them side by side. The RB25 intake is actually larger on the opening than the RB26, due to a larger cut for the injector spray path.
As far as porting, they are about the same as well. I cut up an RB26 head with a band saw, which showed the ports from the water jacket side, to see how far you can port it, and it looks the same at the RB25 head.
