Everything posted by ls280z
Finally after 3 1/2 year i found another datsun project! All new floor pans no rust in frame. Going to go with 5.3 z06cam and 76mm turbo. Powerglide trans on stock rear set up. Worst spot on the car is the doors are kind of rough. Stay tuned for more pics and progress.
Did this deal go thru?
new best for stock long block nitrous 5.3
ls280z replied to ls280z's topic in Gen III & IV Chevy V8Z Tech Board
glide with 2800 stall -
ls280z posted a topic in Gen III & IV Chevy V8Z Tech Board
1.32 60ft 6.06 @111.95 Think ive reached the flow limit for the stock ls1 intake. still on the 230 dru shot. Added 65lb to the nose helped it from wheelstanding couldnt believe how good the car worked. -
Anybody claim this car from Chattanooga Show?
ls280z replied to RebekahsZ's topic in S30 Series - 240z, 260z, 280z
9" ford with 4:10 gear spool big bearing aluminium pinion support and 33 spline moser axles -
yes that would be mine ill sell for 9000 with everything. 3000 as a roller. looking at another project. Everything is still in great shape and is driven on the street alot. actually have it at work today a 60 mile round trip on 93 octane. -
Going to be running a 275 radial street class.
i hope you dont think i was trying to be rude i just keep searching for the record and cant find it. Looked everywhere . my kit is an old school muctang 5.0 dry kit with nozzle opened up for a 230 shot -
sunny z can u find the record? everyone on ls1 tech seems to think it is the record. im talking bone stock never had the heads off stock rings gaskets head bolts absoulutly everything. nitrous and cam only.. even stock injectors and intake stock truck ecm -
Got put out 1st round because of this whhelstand I'll post a pic later to show how high it actually was -
ill have to get some pics of it later. its old school done back in the 80s. air shocks and all lol -
9" ford with ladder bar set up -
bone stock 5.3 ls1 intake stock injectors 230shot dry nitrous 585 lift cam valve spring upgrade. pwerglide 350 gear with 9" ford rear. 76 280z weighs 2910 with me in it -
brought my 5.3 to the track wow what a ride
everyone says that about the injectors my buds 55 chevy has ran 620s with a 6.0 stock with cam for 2 years now with zero problems was featured in car craft issue u can look it up on google shannon medleys 55 chevy. his are only 24lb stock injectors. car slowed down with 26 degrees of timing on motor. went to 24 ran best time then went to 20 on 200 shot made 4 passes on nitrous so far. Also 2 other friends that have stock bottom end 5.3s and one has managed 557 in 1/8th and 561 the other. they both on alchol ported heads and 160lb injectors -
stock 5.3 have two friends putting a 1000 hp on these engines one in a 93 gt mustang ran 5.61 @130mph other just went a 557 @ 121. truckin magizine did an article and made 1400 hp on a 4.8 with twin 76mm turbos.Mine is stock 5.3 with cam glide 9" ford with powerglide. Throwing some new tires on this weekend should run in the 5s -
everyone thinks that my buddy has close to the same set up on dry shot with more nitrous with only 24lb injectors been running 6.20s for 2 years now with no problems even using stock fuel reg. -
stock 5.3 lunati 224 228 585 585 on 110lsa. 28lb injectors and a 230 shot of dry nitrous. First off this thing was a mutt on motor timing pulled out to 20 degrees plus the convertor is super tight nitrous convertor. Also its a powerglide 9"ford with a 350 gear. I was embarresed at first when i let go of the transbrake and seen it had a 2.08 60ft so i ran it on through went an embarrising 8.74 @ 83 mph. I was ready to vomit at this point lol Well turned the bottle on and started with a 175 shot and it clicked off a pretty good time 1.44 60ft 6.48 @105 Pilled it up to 230 shot and it went a 1.35 60ft 6.11 @ 112.98. really wish i could post pics on here i dont have a photobucket account i would post pics. It left so smooth jerked the tires just a couple of inches .
how far foward does your ls sit
i really wish i could figure out how to post pics on here. I have recently got the cam and valve springs swapped. engine is in car have to finish driveshaft fuel system and cooling and shell be ready. hoping this project runs good. Any ideas on weight 280z 5.3 truck motor no bumpers and all interior out except one seat. running 9" ford and ladder bars with powerglide trans. -
Anyone kno how to post pics from mobile phone? -
I didnt do the work on the 9" bit ill get some pics up. I bought the car rolling with cage ladderbar set up with 9" moser axles spool fuel pump weld wheels stole it for 1500 bucks. All body work is done and painted hot rod block not a spec of rust in the car
