flibuoy
About flibuoy
- Birthday 11/02/1944
Gender
Male
Location
clear lake shores tx
flibuoy's Achievements
0
Well I just deleted my HybridZ classified ad. No...I am not going to Ebay the car. It sold to a member of this list who is Kuwait after his tour in Iraq before returning home to Dallas area in a couple months. His dad and a couple gearhead friends hope to complete the project before then. If he shows up asking questions do you best for him John
How much did everyone spend on their V8 Conversion?
flibuoy replied to a topic in Gen I & II Chevy V8 Tech Board
Thanks everyone for the sales pitch for my 260Z project in classified section! John -
I ran that carb on a warm 350. Took it our of box, bolted it on, set idle mixture and speed and drove it 5 years on my first HybidZ. Easy to work on as stated above if needed, though once it is cleaned up good I bet you are very pleased. Of course there won't be as much fiddling as with Holley if that's what you want. I did not run a regulator by the way...mechanical at 5#. John
running a V8 as a daily driver...
flibuoy replied to djc2004's topic in Gen I & II Chevy V8 Tech Board
I drove my first 240Z/350/700R4 for 5 years...everyday.. in Houston. I got it with Scarab position and went to JTR immediately as well as 700R4 with overdrive locked out except in 4th to replace 350 (winds up at 60mph). This car was A/C and had mild cam, headers, intake, carb etc that was pretty stout. 200 rear with trial of both 3:55 and 3:90. Absolutely dead reliable...family has Camries so I know about reliable. It was in build and details...junk won't commute for long no matter what it is. Oh...don't forget...my second Hybrid is for sale....John -
Not an LS but have LT in League City...in storage awaiting finishing...be happy to show it and talk about common FI problems like fuel and in this area A/C. Of course it is for sale too....John
This may be bad form to use this forum...but... my 90% plus Z is in the classifieds without any inquiries. I do need to sell and ad doesn't fully list/describe completeness. I do not wish to E-Bay if it can go to a good home to someone here at HybridZ and I travel too much to list in local paper and answer questions like "is it a 4 door?". My cell is 281-734-0728 and I would be happy to chat about it/arrange specific photos etc. Oh...for you gold diggers the E-Bay reserve will be higher than asking here on HybridZ. John
On third set of plugs in a row trying to diagnosis running problem...all correct for LT1/all different manufacturers/gaps experimented with and caused no change. All eight, on all tries, are showing exactly the same results I don't want to give symptoms...just appearance of plugs after just few minutes installed...to keep from influencing your opinions Plug stays clean..as new.. on one side of tip....rich soot on other half. Not half tip to bottom/bottom to tip...but half as in left/right sides. Transition from white to fuzzy black is not gradual, but almost a clear straight line. I have read every article I could find on plugs...not even a close match to this appearance. Ideas?
I am in the el cheapo bracket...that stock clutch in a Z should be just fine for a long time if not continually abused....perhaps the clutch is not fully engaging due to linkage adjustment....I have stock 305 clutch/flywheel on LT1 5.7 and it is fine John
You might try a search on my name as I have submitted at times on A/C. The stock LT1 mounts will not work...hit frame. Bad news...good news is that Street and Performance in Mena AR has what you need...bad news around $800 plus a Sandel compressor...just over $200. I used the Hot Rod Air evaporator and parts which are nearly identical to Vintage and their largest evaporator fits like a charm. Total cost was around $1400 with tri function switch on dryer, controls, hoses etc. If you decide to go this way you can email me as needed. John
clarification needed for Ford clutch master cylinder
Reread my post...maybe I wasn't clear enough....MC=master cylinder -
Aha...the fly in the ointment...the Datsun and Ford MC rods are different and Datsun end doesn't fit Ford...I used Ford rod with a SINGLE Heim end at clutch arm I happened to have. I think a better solution is search out Ford compatible fork. If rod length is set too short you won't have enough travel after bleeding so it seems like the setup is not working...leave end attached to arm and adjust the rod....way easier than cutting hand to half size so it fits in openings down there. Long nose pliers worked for me. John -
I used the Ford half ton pickup master cylinder. Sorry on year...mid eigthties...it fits center hole perfectly with rubber boot in place. One bolt hole has to be elongated outwards and one is perfect. The hose that goes with the MC also fits the slave on T5, even is about right length. It come with o rings and I think new roll pins. Pedal feel, release etc is fine...like factory wanted it to be. I misplaced the #s and in past I had emailed them to some members so perhaps one of them will respond. The thing is plastic and is probably filled with helium it is so light! Use caution routing hose as it too is plastic and attracted to headers. Price was very reasonable...maybe $80 range for both...the MC is probably a stocked item so you can carry your old one in to compare if nobody sends # in for us. Hope this helped...John -
I have a set on my LT1, but really was disappointed with lengths and size of boots on plug ends...nice color though. I have a random miss and suspect a plug or wires. I did a search...thank goodness for being able to say that! It seems that I have heard of some problems with core breaking down with ok external appearance. Accel? John
Maybe I'll try a clip. The ones I have experience with... the single exhaust flowmaster stocker through true dual big cam engine all seem to sound very similar and not enough definition to form opinion....volume is not a constant from clip to clip also. Maybe when I retire....naw maybe sooner John
I have JTR setup with T5, motor mount holes are slotted as above also. I put adapter yoke in position, slid front of chev driveshaft into transmission and measured universal joint center to center...mine came in at 19 1/4....measure twice cut once as the carpenters say. My shaft was cut, new quality chev yoke welded in to replace the press in/welded factory end, balanced, new unversals installed and back in my hands in about an hour while I watched. John
