I need to add more info next time before I post
The long travel in the brake pedal was there since I rebiult the braking system. I replaced everthing in it, new wheel cyl, new braided brake cabels, new master cyl, rebuilt 4x4 calipers etc and have bleed the things with Valvoline Dot4 about what seems like a 100 times trying to get the pedal to firm up. Like I said, it has no stopping ability until you get to the very end of the pedal travel ( about 1 inch from the end) and then it becomes super sensitve and goes from nothing to fully locked within a 1/2 inch of travel.
The low vaccume is causing the pedal to be a little heavier now but the problem was there before the cam change.
This happens even when the car is cold and I have the brake lines double heat shielded.
The braking is straight and feels even.
It's hard to describe, its not like the brakes are spongy, it's more like there are no brakes at all for the first 95% of pedal travel then the last 5% is were all the braking happens.
Regarding the engine, the thing is a brute, no other way to describe it. I had alot of problems with idle and drivability with the Holly carb and finally sent it back and got a Carter AFB. It now runs perfect!!!
And yes, there is serious traction problems at any speed below about 50mph.
But it is still very streetable and easy to drive if you keep your right foot light.
But there is no doubt in my mind that im in the 475hp area!
Time for flares and BIG *** tires!!!!!
Dan, 78 280Z, 383 450hp?, 700R4 allmost there!
http://members.home.net/dporter1/
