yamahondarider
Everything posted by yamahondarider
Has anyone used the JTR small block mount kit for a big block chevy? In theory it should work, BBC has the same mounts and their the same distance from the bellhousing, and use the same bellhousing as a SBC. I've been searching for a couple weeks on various sites and youtube, using google's reverse image search with pics I found of BBC's in Z's hoping to find a build thread, so far I've found a few builds with dead pictures, and one that still has pictures but they aren't too great. There are a handful of pictures floating around of the motors sitting in these cars, the heads clear fine, but I'm trying to figure out what exhausts people are using. Maybe a stock manifold from? If theres anyone here who's done a BBC swap I'd like to pick your brain and see how you did it. I'm very aware this throws off the 280z's weight balance and makes it nose heavy. I hope to offset that a bit by removing the A/C system and moving the battery to the trunk, I have no front bumper either. However I have no plans to autocross this car, just cruise and light up the tires, and a little stoplight to stoplight drags so I'm not worried about weight balance or hooking up (that'd just tear up the U-joins and R200 diff anyway). I did search plenty, and absorbed a lot of info, I'm just hoping I can hear from someone whos done the swap and find out if the JTR SBC kit would mount a 454 in a 280Z and what you guys are doing for exhausts. Other than that, I've got the bases covered. just need to fill in the gap a bit. Heres some eye candy I've found on the interwebs,
Alright guys, those of you who actually put in input to the question, thanks, I read over the JTR site and missed the part about ordering crossmembers, I saw T56 but didn't see T5 listed until now when I went back to the site. To all you jackass's who think your hot shit, take a ******* hike. If your not gonna post anything helpful, write your comment on a piece of paper, tape it to a 2x4, and shove it up your ass. I'm a damn good mechanic and I've done much harder jobs. But I don't have my welder its in storage because I'm moving and if theres a bolt in ******* piece, I'd rather find it buy it and use it. Just because I don't reinvent the wheel doesn't mean I'm not competent to do such a thing. And to the people who commented I should use the search function (and didn't talk a load of shit), I know, I've been on a lot of forums. I've tried searching for T5 swap but T5 is too short for search criteria, I searched a few other terms and didn't turn up much, but I appreciate the links. Thanks guys.
Hey guys, my Z is a 4 speed and I bought a 5 speed from a friend (same friend I bought the car from he had plans to swap it in). I've searched and researched and sounds like the 5 speed will just fit right in with the clutch flywheel and driveshaft for a 4 speed. I just wanted to verify if the 4 speed shifter, trans mount, and slave cylinder will all work with the 5 speed also? I can't remember if my 5 speed came with a mount but I know it is missing the shifter. The car is a 76 280Z, if that makes a difference. Not sure which Z the 5 speed came out of, but definitely not the turbo ZX. Also, I haven't had a reason to really slide under the Z yet, does the Z use an external slave cylinder that pushes a throwout bearing fork, or does it use a hydraulic throwout bearing? Can I just unbolt this slave cylinder without disconnecting the line and bolt it back up to the 5 speed? I've never bled a clutch before and would like to avoid it if possible. Thanks guys!
Hey guys, I've been looking to putting a 350 in my 76 280z and I have a buddy with a low mile crate engine for cheap. The only thing keeping me from doing the swap is the fact that I can't find any swap kit parts or information (yes I used the search function) on using a regular 350 small block and a manual transmission like a Camaro T5. Plenty of info on LS1/T56 builds and plenty of info on 350/Th350 builds. Does the shifter not line up or something? Trans tunnel too small? No driveshaft parts? Why doesn't anyone swap in a classic 350 small block and a 5 speed?
Are these wheels rare/desirable?
yamahondarider replied to yamahondarider's topic in Brakes, Wheels, Suspension and Chassis
ahh, good to know. Now I won't feel bad if I pull the new tires off em and buy different wheels. Their pretty cool but not my kinda wheel. -
Hey guys, these wheels came on my 280z when I bought it from a friend of mine. So far I've had 3 people tell me these wheels are rare and sought after and blah blah blah. I tried looking them up but don't really know what to call em but personally I haven't seen them before. Their on my 76 280z. Anyone know if their actually worth anything? Or atleast pretty rare?
The Procomp PC 2031, installation instructions here http://www.procompelectronics.com/instructions/images/PC2031.pdf so you can see how it hooks up. it looks like it should work with any car that has a single coil? I assume it works by cutting power to the coil at a certain RPM. In theory, I should be able to wire it through a switch and set the limit low (like 3000 RPMs) and use it as a launch control mechanism of sorts. Does this make sense? so, A) will it work in general as a limiter with the 280z's ignition system and can I put a switch between one of the wires from the box to the car (like between the coil or between the box's ground wire) to activate the limiter when I want.
Hey guys, one thing I've always wanted to do is a 2 step launch control rev limiter but I've never heard of it done on a Z with the stock ignition setup. Has anyone went about doing this? What part(s) did you use? Did you wire the launch control to a clutch pedal switch or a momentary switch on the shift knob, or similar? I don't mind converting to MSD or what have you as long as I'm not paying $500+ to do it. I'd like to keep it all under $200. I don't mind buying used parts if someones selling their setup (this isn't a wanted add I'm just putting this out there while I'm putting up the questions). Thanks guys!
Converting my car from 4 to 5 speeds?
yamahondarider replied to yamahondarider's topic in S30 Series - 240z, 260z, 280z
I've got a friend of mine who'll give me a hand if I ask. I've helped him pull and install the motor in his VW Bug a few times so I'm sure he wouldn't mind helping me put a trans in the datsun. We'll see how it all goes, I'll put a build thread soon enough and the tranny swap will be part of it. I haven't bothered putting a build thread up yet because for the first time ever I literally haven't had to do anything to the car to drive it so I've been busy enjoying it, unlike all my other cars I've bought in the past -
Good to know, I've manhandled a 1952 Dodge Coronet transmission around before so if thats all the Datsun's weighs I should be able to do this pretty easily I'm a strong guy. I do a lot of work on cars so I've got an assortment of jacks and jackstands and ramps and such, I have a fear of being crushed so I take that stuff very seriously. I wish I had a lift but I'm just glad I have a paved driveway. Working in gravel SUCKS So what would it be like to drive the car with the current rear end, and the 5 speed out of a 77-78? Would it be worth it to swap or should I put it on the back burner until I get a matching rear? The rear is making knocking sounds going over bumps and when you shift (suspension clunk) so eventually I have to dig into that anyway. It has all new bushings and such except the mustache bar bushing so I think thats where the problem lies. -
Good to know, thanks for the info. So I shouldn't need to change my gearset or rear diff? Hmmm. How can I tell if my car is a Federal model? If need be do I just bypass that switch and run a straight vaccum line? Cool, I know its not out of a turbo car so it should be a bolt in. Sounds like it won't be more than a day long job. I don't have a transmission jack though, which seems like it'll make it a bit of a pain in the ass to swap. I have a floor jack and a motorcycle jack though, so I'll just get a bit creative. -
yamahondarider posted a topic in S30 Series - 240z, 260z, 280z
Hey guys, I bought a 1976 280Z from a good friend of mine whos had it for as long as I've known him and finally sold it to me (for a good deal too!). Anyway, It runs and drives great but its only a 4 speed and a lot of the driving I do is 60+ MPH and I can really appreciate a 5th gear for highway use. He also has a 5 speed out of another z-car and I'm getting that from him. My question is, do I need another driveshaft, or is that the same between the two transmissions? Also, do I need a different clutch/pressure plate/flywheel or is that all the same between the two transmissions? I'll be ordering a new clutch either way, just want to know which to get. Can I pretty much just yank this tranny, and put the other in or do I need parts from a 5 speed z car? Thanks! Also, I'll get more specific info from him ASAP but as far as I know, its a 5 speed out of a 1975 280Z (thats the other car he had but stripped due to rust but I don't know for sure if its from that car or if he bought it already pulled from another car). -
I daily drive my 1976 280Z. The things I did to make it a little nicer to drive include a grand total of installing the door panels and window cranks, new wiper blades, and I cut the stupid 30 lb muffler off and straight piped it I haven't changed much but since I used to drive a 1973 VW Bug with no working gauges, rotted floor pans, and no suspension, I'm pretty comfy in my mostly stock Z
