I just finished a rebuild on a 1990 sbc 350 roller motor mated to a 350 turbo tranny and put it in my 1978 280Z. I probably don't even have 100 miles on it. I have a difficult to find oil leak. No leak at idle, but after driving it it will leave a puddle under it, and it smokes from oil slinging on the header when driving. So, I put the car up on stands and let it sit and run for around 15 minutes. Again, there is no leak at idle when hot or cold. No noticeable leak at 1,500 rpm either. However, if I rev past that it drips very noticeably from the bottom of the rear main seal housing. Some of the drops hit the outside edge of the fly wheel which slings oil on the header and up in the transmission housing. If I rev the car up a few times to 4,000 rpm or so and then quickly get under it, I can actually see it leak several (7 plus) drops of oil, then it stops leaking. I had two breathers with no PCV, but they pretty quickly became saturated with oil, so I utilized a K&N part that vents the valve cover directly to the side of the air cleaner and I'm not using a PCV valve, just a straight vent to the air cleaner on both sides. It's my understanding that a one-piece rear main seal... 1. typically doesn't leak 2. when they do leak, they'll leak at idle as well as any other rpm. Am I wrong? I've never had this happen and I'm at a loss here and could use some advice. I really, really don't want to have to pull the engine back out. Thanks for any advice.
