Posts posted by inline6
I'm in the Holly Springs area. My Z has been off the road for a couple of years but will hopefully have it fired up again in Jan. Putting the finishing touches on an all new 3" exhaust and still need to locate a diesel water pump for the new motor.
Garrett
Well, in NZ at least, LD28 diesel and Lxx petrol engines have different part codes and details for their pumps
www.STAParts.co.nz
Product Code : WPN-LD28
Description : Water Pump Nissan LD28 1984/10-86 Laurel
60mm from base to top of flange V3-037
Unit Price NZD : 52.98 Each (Incl Tax)
WPN-05A Water Pump Nissan H20 20 L26 LD28 Z16 Z18 Z20 Z24 1969-On 66mm from base to top of flange Atlas Bluebird Civilian Skyline
(Note: This Item is POA - You cannot add To shopping cart - please call or email for $$$)
I've bolded the differences, so they aren't just the same pump used for both applications, I'm not going to buy any to have a look at the impeller tho, I'm off to China on Thursday and won't be around.
So, I've been looking at sourcing a pump from Australia... emailing a Jimmy at staparts.co.nz. My stock pump (L28) measures 66 mm from the base to the top of the flange. The pump they list as for LD28 is only 60 mm. Part number on that one cross references to a WPN-062... not a WPN-079. My hypothesis is that the 062 pump differs from the 079 pump in this distance from back to front. I wonder if just swapping out the front flange would make it 66 mm. Those just press on/off...
Nice resource. Thanks for the link.
I ran an F54/E88 (not the early one) combo for several years. I believe compression ratio worked out to about 10:1. I also ran a "Euro" single point distributor. I think my initial advance was 17 degrees. I had the vacuum advance hooked up and it was functional. Full advance was around 36 degrees by something like 3000 RPM.
The head had mild port work done (intakes matched to stock intake gasket port diameter and only modified about 1" in from the intake manifold surface). Exhausts were ported only in the transition from the bowl to the port runner - again mildly.
I ran the stock cam, stock exhaust valve size and 1 mm larger intakes with L28 valve seats installed... 93 octane was readily available and I had no noticeable knocking... unless I did something like put it in 4th gear at 20 miles per hour and press the gas peddle to the floor. Then I could hear some faint knocking.
So, I list all that because maybe one or a combo of those things helped reduce knocking... I don't know. Seems some people have real bad problems with detonation on certain L series heads. I certainly did not and I didn't have to retard the timing or anything either.
That engine put down 151 at the rear wheels (with early 4 bolt SU carbs) when I had it dyno'ed about 3 years ago.
Price sounds good to me. What brand and part number is it? Would you post a couple of pics so I can make sure it is the one I need? It seems some of the Maxima Diesel pumps are actually not the right specification - based on info I found on this site. One front and one back should be good - and please put "Zentech" on a sticky note or scrap of paper in one of the pics.
Thanks for your help.
Garrett
Thanks. Rock Auto and everyone else as far as I can tell.
I'd even consider used at this point. Let me know. Thanks.
Garrett
Time for an update on the 3" exhaust. I have been working on it when I have time, fitting it all together. This past weekend I finally got to start welding the stainless stuff together with my little MIG welder. It is difficult to make the welds anything but fugly.
The tip isn't welded on yet... I think I like it the way it is (length of it that is), but I'm going to look at it each time I walk by for a few days before I make up my mind.
This 6" round Magnaflow fits nicely:
Rear hanger isn't supporting the weight of the exhaust at the moment. I purposely located the stainless wire here at the bottom of the pipe going under the diff... in the case the pipe drags on the road at any time, this will act as a "pad" to keep the pipe from getting scraped up. I'm thinking the exhaust will drop about an 1/8th once all the joints are tightened up and I remove the jack stands:
Trying to keep the pipe as close to the car as possible...
My ugly welds... I tried practicing on some more scrap tonight.
5" muffler located in the driveshaft tunnel:
Merge collector fitted as close to the header as I could get it:
Lots of pieces necessary here to fit the header to the merge collector:
I hope to finish all the welding this week/week end. Now if I could just locate an LD28 water pump, I could get this thing started.
These are all gone. Not at RockAuto, ebay, Partstrain, Auto Parts Warehouse,etc.
Got one. Re-plated, yellow zinc. Can't ship it till Thursday. I'm in Nashville. Can't see shipping costing too much.
I'll check again on Thursday morning. If you haven't found one, I'll ship it to you.
Lewis
I did find one. Thank you for replying though. I appreciate it.
Still looking for one of these. Willing to pay $50 delivered to 30115.
L series head getting CNC'd:
Yeah, it has gone quiet. I've been working on the exhaust for a while now. The Nissan Motorsports header that I bought (1.75" primaries) hit the driver's floor. Evidently, that is a common problem with it. To fix that, I ended up cutting off the collector and using some 1.75" mandrel bent pipe to change the direction a bit. I also shortened these three pipes as they were about an inch longer than the other three.
Header mods:
Merge collector:
3" stainless pipe:
Fitting the exhaust:
I hope to finish up the exhaust this weekend. Then it's just a matter of last minute checks before the first fire up... -
I have one I think is from a 70 series 1. It has an arm with rubber tip that appears to contact the pinion housing. I'm out of country at the moment.
Check the pic at the link I provided above... I am looking for the all metal transmission crossmember. It goes underneath the transmission and has a rubber isolator between the tranny and it. When you say "pinion", it makes me think you are thinking of a differential crossmember, but I'm really not sure.
My car is a series one. Thanks.
I am still in need of one. When I made my last custom exhaust system, I modded mine a bit so I included it with the exhaust when I sold it a couple of weeks ago. Looks like mine is 70-72 specific.
Garrett
I have this one Brand new never used!!
$40 shipped.
Actually, this is the part I need:
http://www.zcarsource.com/transmission-crossmember-69-71-used_8_52716_50395.html
I knew it was too easy.
Pretty sure that there are two styles for the 240Z - bolt directly to the body with four bolts, and mounted to ears on the body with two long through bolts. You should probably specify year.
It's a 12/70... which is a 1971. VIN is HLS3016511. Two bolts screw in vertically to secure it to the body. Thanks.
Garrett
Sorry... I wasn't clear. I need the metal mount, not the rubber one.
Garrett
Garrett
Nice Power Point that helps people understand exhaust system noise.
Hmmm. Even without the three beers, I don't think I'd follow this without spending a whole lot of time with it. I will say, that my Honda S2000 clearly has a side branch resonator in the factory exhaust. Always wondered why that dead end pipe was there. My theory was it was there to make the two lengths of pipe after the Y the same length... making the tonal quality or pitch of the sound the same for both.
I think all the parts are here. Wondering if this will be enough "muffling"...
--- I kinda doubt it.
3" mandrel bends and straight pipe:
Mufflers, exhaust tip, band clamps, 3/8" rod (to make hangers), and rubber strap hangers:
The Nismo header (1.75" primaries) that needs to be "modified":
The "Merge Collector":
Once the header has been modified to clear the existing floor, I'll be making some connectors to the dual inlets on the merge collector. The header, fabbed connectors, and merge collector are all made out of mild steel. They will be sent off to be ceramic coated. The rest of the system is stainless.
I looked at many glasspacks because I really like the sound of that one video linked to above. I was going to copy the setup as best as I could based on the owner's descripton, but I couldn't find any glasspacks that I thought would be suitable/durable. I have run them before (a four pack) on a true system, and I liked the sound of it until the fiberglass burned out of them. And they were at the back of the car... Most are not stainless (one from Magnaflow was but it had a 2.5" core - so wasn't 3" all the way through) and I came across your post, John, about the Dynomax during my research. I wasn't sure if that one was stainless, but even so, they use fiberglass in theirs...
So, I'm going to try putting the Magnaflow 14867 (5" Dia.) in the tunnel just after the SPD merge collector that John helped me with. At the back, I'm going to try the Magnaflow 12619 (6" Dia.). Both are 100% stainless with no fiberglass to burn out and have 3" cores with straight through perforations. Got a couple of of 3" stainless mandrel J bends, some stainless straight pipe, stainless rod hangers, and stainless band clamps etc. also. The header and the SPD merge collector are both mild steel and are going to be sent off for ceramic coating after I complete the the fitment of the whole system to the car.
I'll snap pictures of the construction and put up a video when it is complete. Have no idea what it is going to sound like... just have to wait and see.
G
I know that 3 inch is big on a NA motor BUT for me a 3 inch exhaust with a decent pre silencer... the sound cant be beat!!!!
this header
and this exhaust has the best sound EVER!!!
Good luck getting it in the states. If you can your looking at 1500+ for the header and exhaust.
Well, I checked out Kakimoto... I'd love to hear it. I just bought a whole bunch of stuff from Amazon - about $570 worth... I ended up picking Magnaflow over Borla. Just haven't historically cared for Borla sound much on the cars I've heard it on and am convinced it would be louder than the "equivalent" Magnaflow unit. So, a bunch of stainless steel is on the way...
It's going to be quite the project, starting with mods to the 1.75" primary Nissan Comp header. One of the collectors hits the floor (driver side). Been thinking and thinking about how best to resolve. I've finally decided. I'm going to weld a plate onto the collector end (shutting it) and fill primaries 4, 5, and 6 with sand - packed really tight. Close off the primaries with another plate (can bolt that one on)... and then take the header to an exhaust shop and have them heat the primaries just before the collector to red hot, so it can be bent a bit away from the floor. I did this with my roll bar when I made it as it needed a bit of tweaking after being bent by the shop I used. The sand packed tight keeps the tubes from kinking or distorting. Yeah... what a pain!
Garrett
I've spent a rediculous amount of time researching choices of mufflers for a new 3" exhaust I will be making. I've listened to tons of videos, but it seems there are practically no 3" systems on normally aspirated L-28s out there, or next to no video's of them anyway. Basically, I don't want to spend a bunch of money and time building a custom system that ends up sounding "ok". I have heard some great sounding z cars and some not so great sounding ones. I'd sure like this one to fall into the first category.
I've found a couple on YouTube that I like:
Since the car is mainly a track toy at this point, I can take it being loud, but not so loud that I can't drive it without my ears bleeding when I am keeping my foot out of the throttle. I've already got some hearing loss, most certainly from a Datsun 510 that I had a 2.5 inch system on it years ago... I used to drive 1.5 hours each way every weekend to see my girlfriend. Anyway, I plan to drive this car to and from the track and on the road every now and then. Has anyone here run just a single Borla XR-1 like this:
on a three inch system? Can it be driven without ears bleeding?
With both of the video's above, the owners are running a combo of mufflers/reasonators. Since the 2.5" system in video #2 is "too loud" for the owner (he added a dynomax bullet), then I'm thinking my 3" with the 40944 will more likely be too loud for me (unless at the track). His motor, by the way, is quite similar to mine.
Video 1 has a three inch pipe, and an interesting configuration - a Magnaflow muffler "near the diff" and a two foot glass pack mounted at an angle after that. Definitely like that the "rasp" is not present with this setup. I wonder if that is the configuration though or maybe 3" pipes reduce that in general.
Here is what I am thinking about right now:
Tunnel Options:
Section of pipe that can be substituted in with band clamps.
Rear Muffler:
Anyone have a 3" system on a NA Z? If so, can you post a video so I can hear it?
3" Exhaust... for NA modified engine. Muffler options?
in Exhaust
Posted · Edited by inline6
Exhaust is basically done now. A few more pics. Going to send off the header and the merge collector for ceramic coating soon - while I continue looking for an LD28 water pump.
The header still needs some welding. I'll finish that when I pull it off the motor - now that the rest of the exhaust is completely done:
Header to merge collector:
A different view of the resonator in the tunnel:
It's a tight fit:
Then the pipe has to swing back to the slot in the rear crossmember:
A good shot of how close the pipe is to the diff 'tang':
6" round muffler fits with room to spare:
Nothing specific here, but you can get an idea of what kind of road clearance there will be.
Rear diff mount "slot" fit on left side:
Again, showing space to diff:
Rear diff mount "slot" fit on right side:
Resonator to floor/tunnel clearance:
