Posts posted by inline6
I have an Electromotive Tec3r that I am planning to use. My plans are for a normally aspirated engine with a redline of 8000 to 8500. We'll have to see what the head will flow, but I'd like to see 400 hp. I am not well versed in fuel injection yet, but I think single injectors should be fine for my application.
If we can find someone to do the block prep and furnace brazing work, I would think they would be more willing to do two than just one.
Lots of research and planning but not terribly far into the execution. I've settled on an N42 head which has had all of valve seats removed and it has had the chambers welded up. There is a lot more work to do on the head. We are working now to determine what to do for the valve train. We're wanting to go with valves with 7 mm stems and beehive springs. Right now, we're researching what spring retainers will work with the nissan keepers (collets). We're looking at machining the diameter down on some of the chrome-moly Schneider ones.
We've got the LD28 block bored to 89 mm, but have to figure out how to proceed with liner design and have yet to source someone to make the liners and someone who can do the furnace brazing operation. We also plan to do Kolene® Kastech® Electrolytic to the block before brazing the liners into place. The next step Bryan will do is exploratory surgery on the bores of the LD28 to learn what we can about the bottom and top decks.
I am not terribly concerned about pace of this project as we are building a 3.0 liter to replace the engine that was in the car for now. The head for that engine is only needing minor work. And the N42 block we are using for that engine has had all of the boring and other necessary machine work completed. I hope to have that engine in the car in March or April.
Garrett
I believe I have some of the factory stuff... nos. Let me get a pic and get back to you.
A perfect fit for me - 5' 9.5" and 195 lb with 34 inch waist. Very comfortable - seems like they were probably made by creating some molds from form fitting foam. With L shaped mounting brackets, they weigh 9.2 lbs as best as my scale will measure. Seats by themselves are just under 7 lbs.
I also got the fabric/fiberglass inserts you see in one pic and some sliders. More weight - but these aren't for a competition car.
We'll need to go bigger with the diesel block, yes. We didn't want the guy doing the boring to do more without Bryan (my engine builder) being there... and timing didn't work out right. The guy that did the boring took more than 8 months to get to it, so we were happy just to get this far. Bryan will do some manual cutting and examination to see exactly what we have to work with - the lower and upper decks. Liners will be custom designed, and may include a step, so we are wanting to move slowly rather than bore out another .120" and just go with what is left.
The N42 will be run as is (after finish honing). After sonic testing, we offset bored three of the cylinders - (4, 5, and 6) .010" for wall thickness reasons leaving the minimal thickness (one spot in cylinder 4) at .170". It seems this N42 would be good for 90 mm... if .150" walls would be sufficient for normal aspiration. The N42 engine will be the temporary replacement in the car until the 3.5 L engine build has been completed.
Here are the bored blocks. N42 on the left, V07 on the right. The guy that did the boring said you could hear that the diesel block was thin while machining the bores. Both blocks were machined to 89 mm (actually about .004" under that). No break through to water on the diesel.
Still looking for a place that can do the furnace brazing. Thought we got lucky with this place only about 30 minutes from Bryan, my engine builder, but they are shutting down and in the middle of moving the equipment to SC.
Finally got the LD block (V07 casting) bored to 89 mm. And, would you believe it didn't break through to water? Crazy I know. But it is obviously paper thin at this point. We'll be doing some more cutting on it to explore what we are dealing with. We're thinking brazing the liners in is the way to go now. So, looking for some assistance locating someone who can furnace braze the LD block. If you have leads, please send them my way. This is not a common thing these days.
Congrats Mark!
A couple of questions:
1. Looks like all of your exhaust valves were hitting the pistons (looks like hitting them hard). Did you conclusively determine the cause? Was your timing chain off one tooth, like happened to me? Or, were the Ex. valves hitting the pistons for another reason?
I have learned that the Sunbelt cam we are both using (the .565" gross lift one) was developed for use with titanium valves. My engine builder knows the guy that owned Integral Cams and worked on the development of our camshaft with Jim Thompson (formerly of Sunbelt). As you know, the AVG3E-L6SPR spring from Jim Wolf Technologies is the correct valve spring for use with the cam, and it has a very light (by comparison with most others) installed and max compressed loads. This spring is handling the additional weight of stainless steel valves, and chrome moly retainers if you are running those. Perhaps valves were floating and hitting the pistons?
2. What ever happened regarding the "reversion" area of the rpm band? Were you able to address it at all? When I was trying to do my dyno pulls (chassis dyno), the operator was telling me to go full throttle from 2k RPM in 4th gear and the engine simply wouldn't do that. It would just choke up and go dog rich. Same thing in third. How were you able to do "full range" RPM pulls to get your power charts, and do you have any of the AFR charts for those runs?
3. Are you running stock main cap bolts? My engine builder doesn't care for them. He says they are too big and don't stretch like they should to achieve proper fastening.
4. You are still running race fuel, right?
5. And I guess I missed it, but what was the most direct cause of the latest engine failure - debris sucked into chamber #1?
Garrett
Daylight between cylinders is proof positive that the block won't take an 89 mm bore. What is the engine number on the plate? Maybe we can get Speedtripper to tell us the number on his as well.
Yes. NZ is where I have been looking to source them. Any chance your sonic tests aren't accurate? And just so we are on the same page, 85 mm is the stock bore, correct? 3.5 mm and the requirement to run no less than .120" inch wall thickness means you couldn't bore that block more than about .010" inches? Just seems to fly in the face of logic that it could take so little.
I just heard back from someone that a sonic test on a V57 block showed 3.7 mm of wall on a stock bore. That's bad news for using a V57 block. You seem to have the only block that has taken a 89 mm bore!
Ok, it is time to start an engine build thread for my next engine. My last engine blew up spectacularly at Road Atlanta. Very disappointing. This one will be off the well beaten path, so there will be risks.
So, here we go...
Block work is stalled for now, but the N42 head is getting some attention. Per the Frank Honsowetz book, the cylinder head was bolted upside down on a block with a spacer to pre-load (bend) the head. The spacer used was 0.040". The welding is not done - this is just the start - welding rod was 40/43 I think. I will correct that if I find out differently.
A few pics:
Engine block will be a LD28, either a specially sourced V57 casting (one Hybrid Z member claims he has one that took an 89 mm bore and left 0.120" or more of cylinder wall), or a one off, custom liner design will be utilized.
Garrett
Hi Leon,
I just read through from start to finish. Really nice car you were able to get from your prof. I was a member of the Virginia Tech FSAE team in 90 and 91. Ah, the good ol' days. Had to LOL at the advice you got to do whatever it takes to finish the car before you got married. I did that over a period of year and a half and she bailed on me.
Sorry to see you are having multiple problems with the head, but thanks for sharing. I came across SI valves as a potential source a while back and now I have more information I wouldn't otherwise have.
Sounds like with Dave fixing things up, you'll be at the end of your issues.
Garrett
The prospective billet crank finally arrived at Rebello. Dave's assessment: "It's a nice crank. It's not one of ours... but it's nice." It's made of solid 4340 and arrived knife-edged. All parties were surprised that the crank weighs in at 51 lbs, with stock cranks coming in around 52-54 lbs.
The vendor for the crank: Thomas Thorman of Sugar Hill Speedshop (GA), (678) 546-6055, https://www.facebook.com/Sugar-Hill-Speed-Shop-1001732356563108. I spoke to Thomas; this is a new part for him and he is still getting the details (mods?) up to speed. I'm not sure what his plans are, but the price I was quoted in its current, raw form was $2,575, "pre-balanced within a gram."
Interesting. I wonder what the stroke is and what the rod journal sizes are. Maybe I'll ask them. I am planning on running Honda sized rod journals. I'll be needing 90 mm of stroke though.
Thanks. Sent you a pm. You need to source some stuff in the US? I am sure I could help with that.
Bump. I wasn't very clear with my first post. I am looking for someone in New Zealand or Australia to buy some parts for me off of trademe.co.nz. I can't register to buy parts on that site being that I am in the US. Looking for someone to buy some stuff for me and communicate with the seller on my behalf. I will pre-pay auction amounts, plus additional for your time. Thanks.
Garrett
We'll see what Dave R comes back with when he gets a chance to evaluate the potential billet crank. I'll likely inquire about a kit, and fully consider my options. Good feedback, gentlemen! Always appreciated.
Very interested in hearing more about this. I have been intrigued about the stroker billet cranks that Crower made for Rebello over a year or maybe even two ago now - per the Youtube video. These were "greater stroke" than the stock V07 crank, but I haven't heard anything more about them. I plan to get a billet crank for my next engine and consider Dave to be a top 2 source for it. Wonder what this new one is...
I am looking for some engine parts that I know can be found in NZ and not in North America. Please pm me for details.
Garrett
Apparently, the V57 was not an official import, but a number of these motors were brought in for conversions in Land Rovers. The net is littered with people talking about this conversion, but the posts are generally 5+ years old. I will post a couple of ads on some of the local 4x4 forums to see if I get any bites.
I have some questions about your block. Can you tell if the front three and back three cylinders are siamesed? That is, are there no coolant passages between 1 or 2 or 3 and none between 4 and 5 and 6? Instead of separated/isolated castings for each cylinder, is each set of three connected/contiguous? And by contrast, there are cooling passages between cylinders 3 and 4?
Could you post some more pictures of it when you get a chance? Front, back, and the two sides?
The pistons you have mocked up are 89 mm diameter?
Garrett
Not my photo, but my Photobucket account (Rayaapp2's photo/vehicle/cat). If anybody does import any of these blocks, and just happens to get an oil pan like the one pictured (winged/rear sump) I would be interested in buying it. Assuming of course, you don't use it yourself...
In to see the stroker progress too, so please excuse the shameless plug!
I sold a pan like that when I parted out a V07 a while back. I would think it wouldn't be "too hard" to find. I'll keep an eye out. Sorry if anyone is annoyed with the digression. We can move the theads for getting the V57 blocks to another thread?
I too, am very interested. I'd want two blocks, possibly three blocks.
I think I would like two also. That is four or five already.
Ok, so you have a friend who can source these blocks? I am seriously interested in obtaining one. And I might be able to get others interested in a group buy.
The V57 block never came the the US from what I can tell. Looks like it might be the version that was used for the factory supplied LD28T (turbo) as well as some industrial and marine applications.
Garrett
Thanks for the pics. Your block is a V57 casting... which has external ribbing. You have a completely different animal there than the LD28 that came to the states.
I found this image of a V07 block in another hybridz thread. Very different even just looking at the exterior, if I am seeing this right.
Regarding uploading pics, look on the bottom right of the blank post area for the next post in the thread and you should see a button labeled "more reply options". If you click that, you will get more functionality exposed including the "choose files" to upload option.
Maybe a group buy of V57 blocks from you is in order!
240z Jute Pad
in Parts Wanted
Posted · Edited by inline6
Here is what I have:
I had two complete, but I used one half of one of these. These are original nissan parts, but they may be a supercession of the original mats and not match 100%. My car never came with factory jute on the floors, so I don't know.
Here is a link to a dealer:
Let me know if you are interested in these.
