Here's some good email correspondence with my Nissan guy that I would like to share.
Me...
"I'm having sealing issues with the 1mm HKS metal head gasket, so I have decided to o-ring the block and use the factory head gasket instead. The question is which is the correct gasket to use?"
Nissan guy...
"I have attached some pics so you can compare the gaskets."
"The part numbers referenced in the pics are:
11044-91MM1 is the HKS metal headgasket that Nissan Motorsports and others including myself were selling- it is now NLA.
(You will notice that the metal gasket is pretty much identical to the early OE gasket in the oil and water passages)
11044-N4221 is the factory non-turbo gasket that was used from 1975 to 02/1981
11044-P7911 is the factory non-turbo and turbo gasket that was used from 03/1981 thru 1983."
"The HKS gasket is just a big-bore, metal version of a 75-80 (N4221) gasket."
"The thing about metal head gaskets is that the head and block surfaces need to be a near-mirror finish(low Ra or RMS numbers) for best sealing.
I have kinda always had heartburn about using the (early style) metal gasket on the later blocks/heads."
"You are probably on the right track with the o-ring+OE gasket setup, however, the turbo engine(P90 head+F54 block) calls for the P79 headgasket, so if you are going with OE, be sure to use the P79 one."
"I remember when Nissan made the changes to both the P79 & the N42 & also the 240Z gasket back in the early 80's and arguing with the mechanics that Nissan would not have made the changes if they weren't necessary, and to trust that the Nissan engineers know what they are doing. It was something about keeping the water in the head longer for better heat transfer to the coolant."
