280zxSheik
Everything posted by 280zxSheik
Bolt in LSX engine mounts for the Z31
280zxSheik replied to nismo kid's topic in Gen III & IV Chevy V8Z Tech Board
I'm very interested in these -
Anyone?
I fixed the previous issues. It was a loose fusable link and a bad turn signal flasher unit that was causing the battery to drain. My next two issues are with the radio harness, in that I have NO constant power, the schematic says that the constant power should be blue wire w/red stripe and ACC power should be yellow wire/green stripe. The car is a 83 280zx coupe, 5 speed. Next I'm working on a TPI SBC swap and I'm getting no power to the fuel pump, distributor, fuel pump felay # 2 on the passenger side engine bay compartment, I have power to the ECM, all fusable links, fuses and starter and most of my under dash relays are clicking. Two that aren't are the large gold one under the dash and the green one with the black, green, white and black stripe and blue w/red wires coming from it. Also the EFI relay and most of its associated wiring has been removed. Since I'm now running the TPI SBC are these components still necessary?
I switched directions and went SBC
Any input?
Update; I checked the circuit for the hazard light since they get a constant 12v. I started at the fuse able links, which were good and receiving power, followed the power wires(white & white/black stripe) to the fuses(all were good) HOWEVER THE SECTION of the fuse block that innervates the hazards is getting no power from the white wire/black stripe that innervates it. I traced that wire up to the ACC relay and ONLY the fat white wire is getting power, the black wire/white stripe isn't. any ideas?
I'll check the coil. I'm getting no power at the fuel pump and the 1st fuel pump relay(under the pass side dash) isn't clicking. I understood it to be the green relay? My Z problems are also a bit more complex. I also have no power in my interior anywhere. I have no parking or brake lights as well as dash or any type of interior lighting.
Im finishing up my SBC TPI 280zx swap and it appears everything is accounted for. I go to hit the key, it cranks but wont turn over. Some things Ive checked are; 1.I'm getting power to the ecm and its grounded but i have no spark at the plug or fuel (at the rail). 2. The battery drains really really fast(within a day) 3. I also suddenly have no interior lights-at all but the headlights work.
I'm trying to incorporate my tpi harness into my 280zx chassis and need some direction, should i be use the 280zx's original engine control relays? If so which relays? Do i need to use a gm relay center or buy a pricey aftermarket one? What can I remove from the tpi harness? What do I no longer need from the datsun original wiring or circuits? Can I eliminate the tpi fuel pump wiring and just keep the datsun stuff? How should I run the electric fans? What about the charging system, starter & how can I rear mount the battery?
does anyone have pics of their jtr trans mount on the trans tunnel of the 280zx? I having difficulty getting mine to mount properly.
Recent update to my 280zx build is I got over zealous with my motor selection and ended up buying a l05 5.7 out of a caprice, a lt1 out of a Buick road master and a lm7 5.3 from a gmc Denali. Right now the LT1 & LM7 are on stands, I put a complete tpi set up on the l05 tbi 5.7and that will be going in the 280zx. Unfortunately some accessories are missing. What starter should I use? Should I use the stock datsun battery cables and wiring? What can i eliminate from the stock TPI harness? The motor has a roller cam l05 from a buick, can I use a distributor from an 86 305 tpi camaro?
I'm in the process of doing a tpi sbc swap in a 280zx. I was curious what throttle cable is everyone using? I have access to many accelerator cables and pedals from many donor cars so I'm very open to suggestions.
Still looking for parts
I'm hoping to do a tpi SBC swap in a 280zx, preferably the vette l98. I have a source on headers but let me know if anyone is selling a l98 motor, 700r4, wiring harness, ecm, aftermarket exhaust or a complete drivetrain. Also looking for motor mounts & tranny mounts. Email me at Conrad280zx@gmail.com
I'm nearing completion of a swap and I'm curious what the Valve Assy-Fuel Check does? I've installed a new fuel pump, that is puming the fuel out the line but when I check at the rail I'm getting nothing. Any idea?
l98 tpi vs lt1 swap in 280zx
280zxSheik replied to 280zxSheik's topic in Gen I & II Chevy V8 Tech Board
Oddly enough the LT1 is more accessible than the TPI cars, they are all over the yards in B Bodies. -
Gvincent Why do you say lt1? Also Does anyone know if there are any differences between the sbc cylinder heads vs the l98 tpi SBC heads? -
Yeah I think ill be going with the l98, I'm not super worried about the wiring. I'll be eliminating alot of the emissions, A/C and most other unnecessary features. The car doesnt have to drive by the end of the summer, just need it to start. -
Unfortunately I have had a sudden change in my financial situation and I need to abruptly change the direction of my 1983 datsun 280zx build. If I'm to keep my Z it needs to be running by the end of summer. (****Please be patient with me since I haven’t been exposed to the v8 280zx in about 10yrs so I might be a lil rusty.***) I'm looking to do a lt1or tpi l98, 4l60/700r4 swap into my 280zx running, for reliability, aftermarket support and ease of swap which option and combination is preferable? Considering emissions aren't a issue which headers fit the sbc swapped 280zx best? If I converted to manual steering would this resolve header clearance issues? I head a rumor that the lt1 headers fit best. Which oil pan has the best clearances? I'm looking to use the jtr motor and trans mount. Is there any literature I should read that can make this swap easier? I have 2 spare 4l60 transmissions from v6 fbodys, if I can save $$ on a transmission purchase i'd like to reuse one of these but will theses be adequate to handle the v8 torque. For cooling I have a l28et radiator & 1.9 ford escort wagon electric fan. I'm using the walbro 255lph FP and I have an after market trans cooler. I have three r200ln diffs w/lsd, one has 336 gears, one has 354 and the last has 390. I'll be running aftermarket gauges. Is there any facebook group for hybridz? Parts I'm looking for are manual rack & pinion Any used swap stuff, aftermarket gauges, used headers, z31 300zx driveshaft, z31 4 lug rear suspension.
Okay so im reviewing the schematics for the datsun and I was unsure if the black wire w/white strip needs to be directly connected some how the the series II ignition module/coil pack? Finally the fuse able links off the datsun body harness obviously need to be connect to power. Does anyone have any ideas about this? According to the fbody schematics there is a heavy gauge purple wire that runs from the starter to the bcm, becomes a heavy gauge yellow wire which runs to the ignition switch after it innervates the transmission range switch. Any help would be useful
Wire colors would be great, but id be happy with some speculation and insight on how the two systems should be combined.
I'd join an ls1 or fbody group/forum. Ls1tech comes to mind
How would you see the camaro series II ignition being wired to the datsun ignition? I have a lsd r200 w/turbo 280zx cv axles so I'm pretty sure I'm good on the power levels I would like to see.
I used modified z31 seats. I also got some 80s model mr2 seats that were considerably lighter but poor material.
Id be interested in hearing more. Personally id source a 351w or cleveland & boost it, swap out the 5.0 and dominate all.
