Turbo260Z
Posts posted by Turbo260Z
I see them going for 800-1000 usually
If they are junk, and fail, you will end up with an expensive boat anchor, that is why . The only reason to run non stock rods is if you are running the engine at high RPMs for long periods of time (over 7k). The Nissan OEM ones are good most most all applications except extreme road race or turbo applications. The best rods are Carrillo, but for $300 each, they should be. This is what we run in in the L28 road race engine.
Yes this will be a turbo motor and I don't think I will ever rev to 7k really. Thanks!
Reckon at Pauter's price point you are probably just as well to go with Carillo, no?
I have read mixed reports on CX Racing's rods, but as they are made in China and low budget, there could potentially be some issues with the quality of the metal they use.
Turbo260Z, any particular reason you are looking at aftermarket H-beam rods? The stock rods are forged, and with the right prep-work are good for all but the more extreme of builds - or so I have read on here countless times anyway. Pretty much all of the info you will need for prepping rods can be found in Honsowetz's book on modifying these engines.
I too have read about getting 500-600hp out of these rods but for $400 H beam rods why not? Especially since I'm building this motor pretty durable I didn't want the week points to be the rods.
I've seen a lot of H beam rods on eBay. Not sure if they are quality. Also have seen CX racing has a set.
Has anybody had experience with these rods? Or know where I can buy a set of 4340 rods with confidence? Thanks!
Hey! I went with a set of forged JE Pistons 87mm (+1mm)
Looking for either or both frame rails and floor pans. Mainly need passenger floor pan but would like both frame rails.
What did you not like about the ACT 6 puck? That's what gained my interest
Looking for a Turbo l28 flywheel. Interested in something lightened and balanced but can be stock. Doesn't have to be crazy light. Can be used or new. Will need it shipped to area code 32812. Paypal ready. Let me know what you have!
Thank you
-Kevin
Starting off saying I have looked up and down for a good clutch, and I have found several discussions on good clutches for setups around 250-300ft/lbs tq. I am hopefully going to be pushing for a max of 400whp and over 400ft/lbs tq on my l28ET build and I cannot find a clutch that specifacally states it's specs.
Can someone please point me in the correct direction for a strong enough clutch for my set up. Preferably someone who has had experience with a specific clutch at that power level? I will be using a 240mm flywheel.
Also what are your views on a lightened flywheel? What weight is best in your opinion?
I have a p90 and p90a. Located in Orlando Fl
Emailed you Steve
thanks for the reply. Just found as set from another source. Thanks!
-Kevin
Seeing if anyone has a set of forged Pistons with rings, pins, etc. also if anyone has a turbo f54 block that is in good shape. Located in Orlando, Fl. Will pay for shipping for the Pistons. Send me a direct message if you have anything! Thanks!
-Kevin
Looking for driver side hood vent. OEM style. Really only need the driver side but will possibly buy both of you don't want to sell 1. Let me know! Thanks!
-Kevin
Thankyou sir. Was seeing if anyone had any that they weren't using just in case. Thanks though!
I already had 4 runner brakes. Need something alittle bit better. Running drums in the rear. I would like something like front and rear willwood or equivalent. Will possibly be running quarters in the 10's so I would like some good stopping power!
Looking for a nice vented 280z hood. Temps are getting hot do to l28et. Let me know what you have!
With custom driveshaft for s30
I have one as well. Located in Orlando, Fl
Need something that I can use with a pallnet fuel rail and will pretty much fit directly into the intake as well as bolt on with the stock injector plastic pieces with the 2 screws. Will buy used if anyone has any or new if anyone knows a good injector. Would love for someone to tell me which injectors I should buy. Thanks!
Anyone have a set of mounts for a 2j swap?? Just need the engine mounts as I am mating a z32 TT tranny to the 2j block
Thanks! I think I blew the rings in my 6th cylinder. Thinking of a 2j now
I don't think you'll have much luck with retaining that factory 4 bolt downpipe. I haven't seen any that have that.
Anything that is along those lines without the downpipe? Was thinking of a 3ich v band
What is the dead time for this injector????
in Fuel Delivery
Posted
Hello I have a set of 1986-87 RX-7 Turbo injectors.
Part number: 195500-1370
550cc
tan tops
Low impedance
If anyone knows the dead time (lag time) for these injectors I would greatly appreciate it. Need it for megasquirt for my l28ET
