Crespo79
  • Location
    Charleston, SC
Recent Profile Visitors
3570 profile views
Crespo79's Achievements
Newbie
  • Dedicated Rare
  • First Post Rare
  • Week One Done
  • One Month Later
  • One Year In
Recent Badges
0
  1. What is your setup? If it's similar to mine and on MS, I could send you some files I have.
  2. I guess I should specify that its not starting or firing, I just hear a few pops and it tries to start but doesn't. I've verified the timing of the cam, distributor, and ran the test mode for the injectors. I smell fuel after cranking the engine and I've also verified that the spark corresponds to the advance in megasquirt, 16 degrees, via a timing light. I'm going to check the distributor wheel tonight and will also take some video of the engine.
  3. Hello HybridZ! First time poster, avid reader and researcher of this forum. I'm posting on here for some help as I've hit a roadblock on my L28ET swap into my S30. I've got my motor completely re-assembled and am at the point where I'm trying to turn it over. The motor is getting fuel, spark, RPM signal to megasquirt, etc. but won't fully crank over and idle. I have a feeling its something related to my Megasquirt/TunerStudio settings and was curious if anyone can give me some insight on my settings in relation to my setup. Been doing a lot of searching on here and have been successful for this swap up to this point but again, hitting a roadblock. Alot of the guides I've found show the setup done using older versions of TunerStudio or Megatune and don't quite match the newest program out now. Motor and setup specs are below along with some TunerStudio and board pics. Thanks ahead for any insights you may be able to give me. F54 .020 over P90 Head Custom cam (unknown grind, has E33/88 written on it though, motor rebuilder had no information on it as the previous customer backed out of paying for the work) Fresh rebuild 7.9:1 Compression 440cc Injectors Pallnet Rail Walbro 255 Megasquirt 2 V3.57 w/ BIP373 Coil Driver, 2.5 bar MAP, Q12 and Q9 middle posts soldered and powered by +12V to injectors) Relay Board 82-83 Distributor (Need to double check trigger wheel, but 95% sure its factory) MSD Blaster 2 Coil Innovate SCG-1 Mishimoto Slim Fan Used a tune from Cygnus as a starting point from the Map Sticky titled "GREAT!!!!!" found here >>>>> http://forums.hybridz.org/topic/34536-megasquirt-map-information-sharing-all-code-versions/?p=906219
  4. Had my Pallnet rail in the car for over a month now with zero issues. Install was a breeze. Definitely recommend!
  5. Sent an email this evening about ordering a rail.
