Everything posted by Stock Car Mafia
Stock Car Mafia's '78 280z LS2 Build
Stock Car Mafia replied to Stock Car Mafia's topic in S30 Series - 240z, 260z, 280z
I had to scoot the boots up about 1/8" more to make the boots stay on. They are some cheap O'reilly boot. I used the part number for the outer boot for both the inner and outer. I drove probably 100 miles and checked and no leaks or ejected grease so far. The flanges I got are threaded as well. I torqued them good and tight by hand, but wanted the extra precaution of a nut to keep them on. I added blue loktite as well. Maybe I am a little paranoid but it plays to be safe on a car that was just a shell a couple months ago. lol -
Exhaust was slow but steady progress until about 8:30 last night. I don't want to rush this and have a hack job exhaust with rough cuts and nasty bends. I truly am trying to use the bend radius for pie cuts to keep everything as free flowing as possible. And drip through will be smoothed out if possible. I started with extending the piping off the collectors. Straight piping worked for the driver side but not the passenger side. I did cheat and angle cut the passenger side slightly and tacked them to the V bands. That small of a pie cut would have been difficult. The V bands were marked with a permanent marker to keep them in line as I was removing them quite a bit. I placed the X-pipe against each side with it roughly centered to get an idea of what angles I would have to add. I don't have a compass, so of course test fitting and cutting little by little was my friend. After I made these measurements, I guestimated roughly how much I would have to extend the piping on the X-pipe to get it to the right width. I taped up the pieces and cut little by little til it was right. Tacked them in place and went back to massaging the end with a grinder to get it just right. I got this pretty damn close and then sized it up again to measure for the pie cuts. I then made my cuts and tacked those pieces on to the collector extensions. All bolted up everything lined up well. I went ahead and welded all of the tubes solid, then to for the final fitment of the X-pipe. After welding everything still lined up REALLY well and quite level. I tacked in about 6 spots on every joint. I welded a 6th of the tube at a time and kept moving around to keep the heat down. This is where I decided to call it quits. I didn't weld everything together as I want to clean up the small amount of drip through where I can reach yet. 1. I haven't determined how the piping will be hung yet. I have some mounts but might go a different direction. 2. The mufflers will be going under the diff and fit well between the front and rear diff mount. I did fit the 90 bends between the back of the diff and the fuel cell cage and it will clear by 1/4" or so so I should be safe. 3. I will mock up the mufflers and measure the angles they are set at just like the collector extensions. I'll then calculate how one bend on each side can be cut: whether I have to remove some of the X-pipe or not. -
Boots are holding up after several test runs. I think I should be ok with them. I am working on the exhaust tonight and instead of scratching my head on paper doing all the geometry and measurements I am going with the ole' test fit and cut little by little. I am working on mating the x pipe to the header extensions right now. It sounds like I will be heading to Green Bay this week for work and have a wedding and family reunion this Friday and Saturday so time will be limited. -
The girlfriend and I were able to get the stock U-joint axles out yesterday and put the Z31T shortened axles in. I will have to say getting the differential stubs out of the diff really suck ass. It took a large crow bar and a 2 lb. sledge to get them loose. The old nuts and companion flanges were taken off and the new ones put on. I torqued the nuts down to 235 ft-lb. The hardest part was getting the right bolts for the axles. I could not find it anywhere on the forums nor did Joe have the information handy when I called him. The right size bolts are: Class 10.9 Flange Bolts - M10-1.25 x 30mm At this length it clears the strut and has enough threads for a locking washer and a hardened nut. The axles went in extremely easy. The bolts were tightened german style and same with the nuts. I used blue locktite for it all as well. -
Thanks for the suggestion. If these clamps don't work out, I don't mind trying something different. -
I think I will be ok. I might just get a banding tool at some point because you get new bands with every boot you buy anyways. I've banded a couple 2 inch banjo's on the transfer hoses we have at work so I know it isn't too tasking. It just takes a couple practice bands to get good at it. I will have to recheck mine before they go in the car. -
Keith, you are right. I think I could do without the clamps, but I'll keep my eye on them for any issues. Smaller hose clamps would be great. Did you have issues with getting the larger clamps to keep the boots secure? -
No, I had to reposition them a little farther down the axle so the worm portion of the clamp doesnt rub. I think it should hold up. -
Thanks bud. I will say this has been quite a journey. Currently I am still driving around with open headers which just sounds bitchin'. It sounds identical to the dirt cars. Just need to muster the ambition to keep working on the car. It's too enjoyable just to take it out every night I can! -
I believe I got my CV's rebuild and shortened for install over the next few days. It may be something the girlfriend and I can do this weekend. I will have to say she almost loves the car more than I do! I started with popping off the dust shields. It was easy by tapping on the outer shell with a rubber mallet. The grease is definitely 30 years old. The shell was knocked off and the ball bearings were popped out. The little circlip was removed. The outer shell was taken off too so I could remove the inner race with a 3 jaw gear puller. This was WAY easier to do than hammering it off. I will tell you it felt like it was glued on. After the inner was pulled off the outer cage came off as well. The boot clamps were removed with a screw driver and hammer to release the clips. The boot was then slid off. Man was that grease just NASTY. The inner CV was a different beast and took some creativity to remove. I know they make an inner bearing race driver that makes this chore quite simple but I opted for the brute force method. This involved a 3 lb. sledge and a large steel chisel. I was "gentle" to begin with to make sure I wasn't going to damage the inner race. The metal must be hardened as it didn't leave any marks on the metal. The best place I found to place the chisel was on the small indentations towards the outer portion of the inner race. I have 3 out of the 6 circled in the photo below. And off came the CV I cleaned both the inner and outer portions the best I could with brake cleaner. You can see where some wear is on these axles. And of course I couldn't leave them the aged green look so I hit them with paint before I called it a night. Here is the comparison between the stock shafts and the ones supplied by Joe at Chequered Flag Racing. I got a little trigger happy and forgot to take many pictures of the reassembly. I repacked the inner CV the best I could by hand. The new grease got worked around a little to make sure most of the air pockets were gone. I removed the circlip from the inner portion of the old axle. This gets put on the deeper groove on Joe's axles. The tricky part was gently bumping the new axle in to the inner CV. The circlip needs to be massaged in as you hammer little by little. When it gets centered and is inserted, you can hammer away to set the axle in the CV. I had a bitch of a time getting the damn boots on. For some reason the boot wanted to keep slipping off as I tightened the hose clamp. I am a little weary of his workin without the clamp coming undone and spraying grease all over. I know RebekahsZ has used the hose clamp trick and I liked the simplicity of it. We will see how it holds up. The inner races were driven on the new axles with a rubber mallet at first. Be sure to put the cage back on the axle before the inner race. I didn't flip my cages and you can't get the cage back on after the inner race is driven on. Once they were flush with the axle, I used a impact socket to drive them on all the way. The retaining clip was put back on the axle. I then packed the CV with grease and assembled the rest of the axle. Again the boots were a complete B*tch! Now the axles are ready to go in the car when I can find time. They turned out pretty nice! -
LS1 Car Club! Post yours!
Stock Car Mafia replied to maichor's topic in Gen III & IV Chevy V8Z Tech Board
1978 280Z - 2,560 lb. after swap - LS2/T56 pullout from an 05 GTO w/ stock harness - Hawks Third Gen weld in motor and transmission mounts - C6 LS3 Oil Pan - Hawks Third Gen Longtube Headers - 3" Dual exhaust with custom X-pipe and Dynomax Race Bullets - Ported and polished Intake and TB - VRX5 Camshaft: 236/238 .601/.605 113+2 LSA - Mightymouse catch can - Monster Stage 3 clutch w/ 18 lb. flywheel - 3" Aluminum driveshaft with billet slip yoke - 9 lb. - Z31T CLSD R200 - Chequered Flag shortened half axles - Chequered Flag companion flanges - Tilton 7/8" Clutch MC - Wilwood 1" Brake MC - S12W Toyota vented brake upgrade - 14 gal. Jeg's fuel cell - Bosch 044 fuel pump - -8AN fuel lines - Ground Control weld in coilover kit - Tokiko Illumina shocks - 225/250 springs - Energy Suspension polyurethane bushing kit - Rota RB-R 17" x 9.5" on all 4 corners Started the swap November 18th and turned the key on May 27th. Started driving it May 30th and haven't looked back! -
Electric power steering. $100 > $1500
Stock Car Mafia replied to sectumsempra's topic in S30 Series - 240z, 260z, 280z
Wow, I am definitely interested if anyone works on this before I cross this bridge!- 74 replies
- power steering
- electric power steering
(and 1 more)
Tagged with:
Those gears look a little rough...I am kind of curious to see what kind of torque the stock T56 tranny can hold in these cars. I think that motor would have been quite different to stuff in to a Datsun! I just placed my order with Vengeance this morning. They suggested going with just the VRX5 cam: 236/238 .601/.605 113+. I went with the 8660 steel alloy cam. I picked up the 0.660" dual valve springs with titanium retainers, hardened pushrods, and the newer bushing trunion upgrade kit. I've read a lot about premature wear with just the Comp Cams trunion kit. The bushing kit seems relatively new but allows the trunion to spread the load out more over a larger surface compared to the needle bearings. There is a ton of info on the LS1Tech site on this. Here's the data from the alignment done with "The Alignment Guy" Jeff yesterday. It was only $50 to have him true up the front and check on the rest. I really can't adjust much in the back but you can see there is some need for adjustability if I choose to road course at some point. -
CXRacing 1973 240z Rebuild 2JZ RB25 LS1
Stock Car Mafia replied to CXRacing's topic in S30 Series - 240z, 260z, 280z
Holy moly....that color is just O.o What dark gray color code was used for the hood? -
The only bad axle out of the bunch is the rusty one. I am might just steal parts from it here and there. The ones I rebuild had decent boots that weren't torn. They look find to me but you can see the wear marks on the outer cage which I'd assume is normal. I think I got them right when I was looking at them. Shorter shaft and shorter stub = Driver. Longer shaft and longer stub = Passenger. They are rebuild now and ready to go in the car. I fracking fought with the damn boots for 50 or so minutes trying to get the effin' hose clamps to tighten without the boots slipping. It doesn't help everything you touch gets covered in grease. -
I hear nothing but good things about those guys. I took the mustang there once to do a couple pulls to check an email tune I had. Solid guys who love what they do. Running E98 is just nuts. I don't know how you ever got bored with that thing! -
Just a small update. I've been driving the car everywhere I can! I've got about 650 trouble free miles so far. Front end alignment will be done tomorrow at noon. I have a small window to play around with the collection of CV axles. I ended up tearing in to the pair that had a boot missing (that came with the CLSD diff). I got them apart with relative ease and will do a write up on it as I wrap it up. I decided to scuff and paint the parts too as the green is not attractive to me. I called DB Performance in Rogers, MN about any tuning sessions that may be open in the next month. They were pretty booked solid. July 15th is the state car show I really want to be ready for so I the soonest I could get in was July 11th. Just in time. I have 5 weeks to get the following done on top of weddings, graduations, plans, etc. - Route and finish exhaust - Rebuild axle and install - Possibly reroute intake tube to front of radiator? - Install cam and components -
We're not in Kansas Anymore build
Stock Car Mafia replied to Onetype's topic in S30 Series - 240z, 260z, 280z
This build should be pretty epic! -
That explains a lot! Keep up the great detail. Its always a joy seeing your updates.
What camera do you use for your pictures? There is just so much detail! I love this build thread
BLOZ UP, do you have any estimation on how much the VG weighs compared to the stock L28? I'm sure yours will still be light. I'd like to gwt mine on a set of scales. The flares were really quite easy. I haven't started tack welding and seamsealing but the fitting is critical. I had to warp the front a little wider to make enough room. I don't feel guilty because the purist have their own mind set! I was nervous though. I mean the car is in great shape and I would hate to mess it up! -
Last and not least I did receive the shortened half axles and companion flanges from Chequered Flag Joe! There was a snafu with the Postal Service mishandling the package. Joe shipped it on the 19th I believe and it was shipped but shown no tracking scans or updates. It finally populated data yesterday and shows no record of it crossing the states between here and CA. From what I can tell is the box was poorly handled and badly damaged. They shrink wrapped it all but of course the parts were banging against each other and the zinc plating is nicked in quite a few spots. Now the next steps of the dream are as follows: - Get a front end alignment. - Rebuild axles so the car can go on the dyno. - Get a cam and install this along with new springs, titanium retainers, pushrods, and possibly an oil pump? - Get the car on the dyno and dial it in. I hope I'm not boring anyone with my posts but DAMN I am more than stoked to have the car on the road! I am enjoying the car more than I probably should! -
I forgot the post any pictures of the flares! I replaced the thermostat for cheap insurance. Here are the flares after I got them all bolted. I must have been in a hurry and got one of the rear nutserts misaligned in the rear. The whole was drilled oblong and I didn't think twice about it. Lesson learned. The great thing about where I work is there's a scrap yard across the road. They have been very kind with working with our business for some time. I was able to get the car on the scale last year and now this year again. If I recall right, the car was 2,680 lb. without me all stock. I pulled on the scale and was SHOCKED to see 2,700 lb.! I had to step out just to see the actual weight of the car... 2,560 lb. Keep in mind I don't have my exhaust fabricated yet but all the interior minus a couple small trim pieces are in. Definitely happy with this! I just can't stop looking every where I stop... It's been pretty astounding by how many people want to stop and talk. They either know what kind of car it is or ask "what the hell is this thing?" I've got about 300 miles in the books over the last two days. Everything seems to be working great so far. I've gotten in it a couple times and this thing is like a bucking horse! The diff I got is pretty noisy. It howls while slightly getting in the gas in 5th/6th gear. I did check the run out and backlash prior to installing and all spec'ed out. It may have been run incorrectly from someone else in its lifetime. The fuel pump works great so far! I can hear the sound of the pump get just slightly higher in dB (very very little increase) when I get around a 1/4 of a tank so I've been sure to fill around this time. I already have filled up 2 times since getting it on the road -
From that shot, I'd say the car is EXTREMELY clean. Good find!
