        cosmo
                Posts25
Everything posted by cosmo
	trans is still available, didn't need the shift fork nor throwout bearing so it comes with both, no speedo cable though. must go!
	Looking for a pantera style hatch for my 280z. Thanks!
	Yes I am pretty sure I am missing shims. Do you have a picture for reference? Thank you!
	I completely disassembled my turbo dizzy to clean and paint it. However, now I am not 100% sure how to put everything back together correctly. After putting it together there is quite a bit of play in the input shaft so the trigger disc can touch the sensor. FSM didn't help Thank you!
	just pulled my trans, 5speed out of a '83 ZX N/A trans is in great shape, works flawlessly, shifts smoothly comes with short throw shifter. without speedo cable, throw out bearing and shift fork. (need that for the other trans) $450,- (local pickup in Costa Mesa)
	Afraid my 5speed won't hold up to the turbo upgrade. Due to shipping costs, preferably one in the LA area. Thank you!
	I tried the search, but it wouldn't let me search <4 characters. I read mixed reviews on the XTD clutches, but none ran it on the Z. Anyone running the Stage 4? Would love to hear your opinion, as the EXEDY stage 2 is 4-5x as much. engine: built L28et, ~350-400hp This is the clutch I am talking about: http://www.ebay.com/itm/201808445862?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT vs https://www.stillen.com/performance/transmission-parts/exedy-nissan-200sx-240sx-280z-280zx-620-720-810-maxima-stage-2-cerametallic-clutch-kit-06953a/vehicle/1975-nissan-280z.html Thank you!
	Yes good point, I honestly don't even know what brand that MSA kit is.
	Thanks guys -makes perfect sense now!
	Please move if this is not the right section for it. I was wondering if anyone had documented their A/C install as the MSA A/C kit 'manual' is a joke and useless. This is the kit I am talking about: http://www.thezstore.com/page/TZS/PROD/classic09b06/16-7568 Thank you!
	The degrees you can read off the pulley with a timing light are based on TDC of piston one as far as I know? hence I should be able to tell the camshaft position since the crank and cam are linked with a chain.
	But the ECU knows TDC from #1 piston from the Crank sensor. Same as reading it with the timing light from the crank pulley.
	But since the cam is connected to the crank it shouldn't matter? 1/2 crank rotation = 1 cam rotation Knowing the crank rotation I should be able to tell the cam rotation?
	Can I use fully sequential injection with only a crank position sensor? (Hoke trigger wheel) My MS3 gives me an error saying I need a cam position sensor, but knowing the timing of the first cylinder should be sufficient to calculate the rest? or am I forgetting something? Thanks!!
	Thank you! I got a 50mm wastegate and will add the piping directly to the manifold. As for the pistons, I will wait and see how the current pistons look like. I am still not sure if forged or just dished. I will go for a safe tune, monitoring as many things as possible. Thank you again for all the info -- helped me a ton!
	You are absolutely right, just re-did the math with the SX252e and I'd need 13.8psi to get to 350 on the crank @6500 -- see map attached. Do you think a WG spacer will do in this case? I am still unsure if I should: run the flattops with a stock gasket flattops with a thicker (1 or 2mm) gasket get dished pistons go forged
	That's what I was fearing especially running close to 20psi of boost. So I guess I'll have to get the manifold welded.
	Thanks @seattlejester!!! After checking these out I have to admit I really like the S252SX !! I thought of getting the GT28 before but after all the research I think it might be a tiny bit too small. I will be running a wastegate (T3-T3 spacer with WG outlet) to get the boost under control. Thank you!
	Thanks for the input guys! I wanted a quick spooling turbo but you are right, after going through all the maps 3k sounds pretty 'right' to me. I thought of either getting forged pistons or getting a 2mm metal gasket which would give me a CR of 7.86:1with the flattops. 91 fuel, Megasquirt 3Pro (at least that's the plan) This is the turbo I thought of getting:
	A few things still needed for my turbo build: T3/T4e turbo (T04E 50 trim, .63 housing) Wastegate Intercooler Fuel pump MS3Pro (highly doubt someone sells one used but you never know.. ) Fuel pressure regulator 240SX throttle body Let me know what you have! thanks!
	Thanks guys the links helped a lot!! So after doing some math, I got to around 37.95 lb/min for 345hp (should get me in the 300whp ballpark) which then translates to around 18.4psi of boost (calculated with 5.6k RPM) and a pressure ratio of 2.55. After translating that to the compressor maps I saw that the 60-1 is definitely too big for my needs/wants. So my favorite right now: T04E50 Trim, what do you guys think? Also, does anyone know where to get ALL Turbonetics maps for their current lineup? I only found 7 on their website.
	Thank you guys, I guess they will be too slow then. Can anyone recommend a turbo that spools quickly (around 2.5 - 3k) ? thanks!
	I am currently converting my Z from carbs to turbo. F54, P90 head, flattop pistons, 60mm 240sx tb, 440cc injectors, intercooler, upgraded pump and lines I want between 300-350hp to the wheels and want the turbo to spool between 2.000-2.500 but also have some top-end power. I currently have my eye on these Turbonetics options: T3 w./ 60-1 HiFi, st. bearing, oil cooled, F1-57, and .64 A/R (maybe .48?) OR T3 w./ T04E Super 60, st. bearing, oil cooled, F1-54 and .64A/R What do you guys think would be my ideal choice? Thank you!!!
	I also just changed my alternator with the 60amp zx. I will have to look into the wiring and will also add a capacitor. Thank you
	I will definitely look into this! I have a new Speedhut Tach, so it must be a wiring/condenser issue. Thank you
