Ive started my wiring saga.  Ive got the 6 stock injectors plugs ready to wire to the EK6 Harness.
The loom digram for the injectos has 7 wires
-DIG OUT1
-DIG OUT2
-13.8VDC INJ
-INJ1
-INJ2
-INJ3
-ING4
Im going to be doing batch firing on my JZ, 3 injectors output firing 2 injectors each.
Each injector pair has 2 black wires and a common white.  Do INJ1-4 provide a ground and I should run the negatives of the pairs to them and wire all the whites to the larger 13.8vdc wire?
Not a total idiot, but Im having a difficult time on this one.
This help point me towards the wiring order, maybe help someone answer my problem?
The E6K can only provide 4 fuel outputs, therefore it cannot control each cylinder’s injection
on an engine with more than 4 cylinders. For 6 or 8 cylinder engines, the E6K can operate in a
semi-sequential mode. With the Ign / By set to 2, each injection will occur once per engine
cycle. The injectors need to be paired to cylinders adjacent in the firing order. For example,
on a six cylinder engine with firing order 1-5-3-6-2-4, the injectors would be paired to fuel
channels as follows :
Channel 1 INJ1/INJ2 cyl 1 and cyl 5
Channel 2 INJ3/INJ4 cyl 3 and cyl 6
Channel 5 Digital Out 2 cyl 2 and cyl 4
