Thanks for the help, man. Exhaust system is freshly redone with a brand-new cat. The intake is a cold air intake style tube with a cone filter. The car has always been kept inside, in SoCal, there are no mouse nests or shot out aspects inherent to total neglect, nothing like that. Just sat for awhile until around last year, and since then I've been getting things back up to snuff especially now that the crazy man isn't upstairs calling the city and the cops on me every time I turn around. By "The balls it used to" I'm referring to when I rebuilt the top end and did some other work about ten years ago. When I first got it running again last year (replaced the clutch) it ran a bit rough in the high RMPs; new plugs and cap pretty much fixed that, but it doesn't pull as well as it once did into the high RPMs. I've found and fixed several vacuum leaks, and that has helped. There may be more of them, especially in the rubber elbow just before the throttle body- it has some cracking. I'll get to that soon. For now, I'm wondering about these injectors. Sorry to have left this out, but cyl #5 AND #6 injectors are silent, even when their respective leads are switched with cyl #4, whose native injector is clicking as it should. But when #5 or #6 injector's leads are disconnected, the engine's idle is noticeably rougher than with their leads in place. In other words, the injectors in cyl 5 &6 are silent under all circumstances, but are still contributing somehow to the engine running semi-properly.
If it matters, the engine is F54 block with P79 head, metal head gasket (the MSA one, forget the mm at the moment) and Scheider cams, stage III I believe with modified valve train elements as well like springs and guides. Intake like I said, Headers, high flow cat and magnaflow exhaust. I might be a bit vague on the specifics, it's just been a long time and probably thousands of beers since I did the modifications, and I had a friend/ mechanic who honestly did a lot of the stuff that was over my head. Some things in my memory have been covered by the tides of time. I appreciate the help again, I'm really enjoying getting back into it, and this place is a huge help to me.
