Hey guys, yes I am getting very heavy backfires. The tps is getting checked today. As far as the walls getting flushed down I thought it was because of the oil smell out the exhaust but just discovered I sometime in the past week dropped a ringland or piston ring. There is scoring on cylinder wall of #1, which leads me to believe that the cylinder wall flush down may have contributed to the scoring. Compression test results showed 110 psi on cylinder #1 with the engine cold and 90 psi with the engine warm. All other cylinders check out at 150 psi. Newzed, my z31 system consists of 86 z31 turbo ecu, maf, cas, and optical wheel. tO4e turbo, front mount intercooler, stock injectors, rail, fpr and tps. My main concern is that if I am going to replace all the pistons and have the block honed, if the injectors are still firing on decel and causing washdown it will lead to bottom end problems again so I am trying to get this figured out before the rebuild.
