Paul johndon
Everything posted by Paul johndon
  1. While cranking dose your scan tool have a reading for pos count, if not it won’t start. Usually you don’t have a good ground from trans to engine. Try making a ground loop wire, and pulling out a trans bolt that has a nut and bolt (bottom) a 3 inch long wire about 10 gauge with an eyelet on each end. Install wire loop with one end on engine side and one on trans side. As soon as you start cranking you should have a poss count, when you see that it starts. Paul. 25 yr Nissan master tech.
  2. I have the knock off greedy intake and spent a few hours trying to clean it up and get it to fit right. Also there’s no place to put aux air regulator for fast idle. I put a Q45 throttle body that has a thermal element (wax pellet) for cold start fast idle. You’ll need to run small coolant hoses to and from the t/body. Worked well on my 77 280z rb25det. Paul johnson. (Nissan master tech for 25 years)
