I’m getting fuel from the pump to the rail 40-36psi cause I got hot wired to a relay and fuse . But it’s not throwing fuel from the rail to the injector out . But sometimes i will leave it alone for a while and it will start for a second or two and die out . This is the list what I bought for it brand new : fuel pump , alternator, ignition switch , ignition coil , distributor , battery, wire set , spark plugs , fuel filter ,new engine valves /lifters , mass air flow sensor ,  cylinder head temperature sensor ,new injectors and new oil sender .
	My problem is the injectors are not shooting the fuel out . I unscrewed them out from the manifold and put it on top of a box and turn the key nothing comes out but the  s130 was running perfectly fine for almost 150 miles with no problem after I put it back together . It ran beautiful the. Just shut off and never wanted to run again smh 🤦♂️
