Ok, I've double and tripple checked the wiring to the ignition system, injectors and home/trigger system. It all seems correct. I have the W to the trigger wire (G/B on distributor), and the W/G to the home (G/Y on distributor). I have 13.8v to the B/W wire on the distributor. turning the distributor will start the fuel pump, but it only registers a fraction of the true RPMs on the ECU. On the injectors, I am getting voltage on one side, but not on the other. Shouldn't I have voltage on both wires? On the ignition wires, I am getting no voltage at all.
I have a feeling my ECU is screwed up. It doesn't fire the injectors and it doesn't fire the ignition when I spin the distributor. I do get readings from all of my sensors, and the TPS will calibrate. I would post my screen shots of the setup, but I don't know how.
Is there anyway to diagnose the problem here. I got the ECU second hand. I hope somebody can help.
