oldschool2
About oldschool2
- Birthday 03/06/1966
Gender
Male
Location
Las Vegas, Nevada USA
Interests
Martial Arts
Recent Profile Visitors
oldschool2's Achievements
0
Post some blacked out ZX's or ZX's with ZG flares
oldschool2 replied to BluDestiny's topic in S130 Series - 280ZX
Hello, My 1982 non-turbo will turn-over and not start if I put the Wrong KEY in the ignition. I have done this 3 times in 3 1/2 years. When I realize that I put the wrong key (door key) in the ignition, and put the ignition key in, as intended, the car starts. I did this again about 2 weeks ago. Same thing used to happen with an old Tercel I had.
Hello, Thanks for the detailed information. Nice to get a reply that actually explains something. WD 40 (WD = Water Displacement) is big in the USA. Royal Putple Maxfilm is a newer (and much more expensive option).
Good Day, I have bought Two replacement flashers from Nissan Dealers in the USA at $50.00 each. I also have tried a cheap $10.00 one. Results are the same for each. They work then they do not. The USA version of the 1982 280zx definitely has only one Flasher that controls the Hazard and the left / right flasher. Currently everything works. Tomorrow it may not. So far the flashers have worked for about one month. Previously (when hot) they were not working (left turn) for about a month. This has been a cycle going on for three years. Took me awhile to connect the outside temperature (weather) to what was going on. I am looking for a switch to disect. I am not sure as to how the assembly is held together. In other words I am not sure if the switch can be disassembled and then reassembled.
I have been pestered by my turn signal not working for 2 years. It works then it does not. It is not the flasher. Sometimes the left turn does not work, sometimes the right turn does not work. 1982 zcars have one flasher that works with the TS and Hazard. Hazard works fine. The weather has turned cold (for Vegas), temps in the 20 to 50 degree range. Now that it is cold the turn signal works perfect, and has for a couple of weeks. I can only guess that there is a contraction/expansion going on that affects the TS switch. Any one else ever experienced this TS situation?
Try the below site. http://www.xenons130.com/reference.html
Move to Las Vegas and you will be required to due a Smog Test every year! Also, I get thumbs-up and frequent compliments on the appearence of my 280zx 1982. Even Porsche owners like my ZX.
turn signal switch cover removal? 1982 ZX
oldschool2 replied to oldschool2's topic in S130 Series - 280ZX
Thanks for the info.. -
I have an intermitent turn signal problem. Sometimes it will not signal left. Sometimes it will not signal right. Hazard lights work OK. FYI: 1982 has only one TS flasher for both the Hazard and Turn Signal. I have replaced the flasher 3 times. Specifically, I am trying to get the top cover off the steering column that the switch sets under. Sometimes when I jiggle the TS switch handle, the flasher works for awhile then stops. Maybe there is a loose wire in the turn signal assembly, but I can not get the cover off to check-it-out. Also, where in the front headlight area do the turn signals GROUND? Thanks
Hello, Look at my post on this forum titled: Fuel Tank Vacuum and Fuel Check Valve. You can probably skip to my post #15, #18 and #19 to see whats-up. You also need to be sure that you have the proper fuel cap that has a vacuum check valve on the bottom. Courtesy Nissan in Texas is the only source I know of.
Oil Pressure Sending Units are available on Ebay, www.motorsportauto.com and www.blackdragonauto.com to name a few.
Not sure how long you have had your car, but when I first bought mine, I had a set of two ignition keys that appeared the same when held next to each other. Twice I had a zippo response (about like your problem description). I figured out that only one of my keys would work 100% of the time in the ignition. Both keys looked the same when compared side by side. I had a similiar problem with a toyota. Otherwise, I would look for a blown fuse @ box on the inside passenger side kick panel.
