10
BluDestiny last won the day on April 8 2019
BluDestiny had the most liked content!
About BluDestiny
- Birthday 03/16/1990
Gender
Male
Location
Cedar Rapids, IA
Interests
Z-Cars
Recent Profile Visitors
BluDestiny's Achievements
T-connection for Valve cover and crank case hose to balance tube?
BluDestiny replied to BluDestiny's topic in Nissan L6 Forum
After reading the Arrington CCV Bible it looks like I actually want a dual catch can setup, with both the crank and valve cover returning through a filters catch can to the intake plenum, or somewhere before the throttle plate. This eliminates foul air modes at WOT and in either direction will still function. The PCV valve itself can be a choke point specifically at WOT due to increased blow by. The difficult part is that I have dual SU carbs that have no "plenum" and are essentially open to atmospheric.- 1 reply
- 1
Hello, I'm trying to install a catch can on my 240z with an L28 with SU carbs with individual carb filters. Right now, the crank case vent runs to the balance tube through a PCV valve just like oem. No issue there. The valve cover however has one of those tiny filters, since the stock airbox for the carbs is gone. My understanding of the system is that the crankcase is used to draw air out through vacuum through the intake. The valve cover is designed to draw in fresh air at idle to the engine, but under WOT would not be pulling air. I want to run a single catch can to tie together the crank and valve cover hoses together, and run the outlet of my catch can back to the PCV on the balance tube. I'm wondering if that's correct, or if I have to run the valve cover vent separately to a location in front of the carbs to pull fresh air or if I can connect it without a PCV to the intake. I found this picture on here, but the outlet going to intake does not indicate the PCV valve. which is what has me questioning my idea.
I am bringing this back from the dead as I am now digging into a vibration that I'm experiencing at anything above 60mph. I pulled my driveshaft and am getting an aluminum one made with spicer joints. Diff flange to rear of trans is 24" on the dot. I have already dropped off my old DS, and when it was installed it was snug, so the DS shop suggested a slightly shorter by about 0.25" I also looked into the actual alignment of my driveshaft using a laser level. The cross is about 0.75" off from center, which is just under 2*. I think that's fine, but someone please let me know if that's too much. Lastly, some general problems I have with the T3 kit after using it for 4ish years. The moustache bar hits the spare tire well, to the point that it's dented the metal. Below are the pictures, which most people don't see. It is keeping the diff inline though which is nice, but the spacing could use some work. The RT mount with a snubber also seems to have an issue that I just noticed since digging into it as well. Due to moving the diff rearwards, the snubber is now contacting the rotating pinion flange. It seems to have self clearanced, and when everything is snugged up I can still turn the flange by hand albeit with a little strength needed. I can't move the RT mount further backward due to the lip on the metal, I would have to drive that away to do that, I may try that and instead of the snubber, I will use the GM bushing that bolts to the diff. I am also going to change the front diff mount out for a T3 piece as from what I've read there is some slotting to be able to move the diff and align it better. I have recently also started the swap of my Koni struts into the strut housings, so I will post progress on that. I'll be getting new top hat bushings since one of mine just split in two when I was taking it apart, but I am essentially going through all my rear suspension at this point. The koni yellow 8641 1031SP1 is the same length and fit as the Tokico BZ3015 which is historically the strut people would use when they section the rear. I will report back with the fronts, it should be a 8641 1142 koni yellow vs a tokico BZ3099. The difference is the gland nut provided by Koni, the tokico has an inner ring that won't fit in the strut housing with the strut.
I already have perches welded on. The owner who did this must have kept it longer than normal for the suspension travel, which means I just have to use spacers to keep the articulation points the same. So that helps a lot. I just need to get the spacers and inserts to match the tube length and I should be good.
So what you're saying is what matters is if the spacer is there to make up the distance to the gland nut. I can then leave the tubes themselves the same and make sure the insert itself comes right up to the gland nut. I am artifically raising the car by however much that spacer length is in the tubes. Then I can play with whatver length springs I need to really get it centered. Or are you saying the spacer is needed because of how the tube is centered and welded to the cast portion?
So I bought my 240z with sectioned struts, tokico illumina struts and hyperco springs. My driver front was leaking so I decided to take some time this weekend and see what I actually have. My fronts are Tokico BZ3099, the common 87-89 MR2 rear struts, and my rears are Tokico BZ3015, which are 240z front strut inserts used in the rear. Since tokico is no longer available I'm thinking of just going with koni 8610's since this is mostly a track driven car at this point. The problem is in the measurements. Below is an except from the strut sectioning sticky by John Coffey So in the front, the koni's require about 0.55" less length than the illuminas, and the rears are the same. Koni's need to have an overall length of approx 12.9" and illumias need a total length of 13.5. The rears are the same for illuminas and konis at 15" The problem I have is my measurements are a little off. My rear overall tube length is 15.25" with the perch at 9.5" from the bottom of the tube, and my front tube is 14" with the pearch at 8.375". My rear spring is a 10" 250lb hyperco spring, and the front is a 9" 225lb spring, both on 5" sleeves. I have not fully removed the insert, just enough to see the part number. I have to assume there is a spacer at the bottom of each to fill the space and bring the strut insert to the gland nut. I want to drop in the Koni 8610-1437RACE inserts and increase my springs to 325f/350r rates using 10" springs as listed in the faq. Does that sound feasable or will I need to section my struts again to get the proper length?
I went to 2 machines shops, Burbank speed and machine and Deed automotive in moorepark and they could do it for about $400 for machining only, but it cost less to ship it to and from texas for Godzilla to do the machine work. Myself and a friend shipped Godzilla about 4 bellhousings to have done to cut down on costs.
So this is the members projects, not a question sub forum. But, all the factory service manuals are available on http://www.xenonzcar.com/s130/fsm.php and you can find the wiring schematics from there (not in color which sucks).
All my suspension clunking is gone. The car is extremely solid now. The steering is a lot more reactive also. Overall I can't wait to try it out on the 21st at Buttonwillow. Also started the process of rebuilding an SR trans and and just waiting on a machined L series bellhousing right now from Godzilla Raceworks
The driveshaft is from a 72 or later S30 Z (as long as it had a manual trans). The biggest thing is to check the length, which I posted pictures of. I did try flipping the T3 mustache bar, but the drop mounts would not line up. That was before I even got the diff lined up, so it was an immediate problem. The T3 bar is meant to be mounted more towards the gas tank. It's a fairly tight fit with all the T3 stuff. I'm bringing the car to get aligned this week since I just eye balled the toe everywhere. Will have first impressions of the drive after this weekend.
The usual "I got a guy". It still has valid Iowa registration, so not too concerned as I don't drive it daily at all. But I will need to take it in before end of May.
