Everything posted by long240project
Yes 13 year old strut come up perfectly...so did my original ones. If you were ever to replace them that would not be the case. Reason I replaced mine is because the car sat up for 4years while restoring. I didn't replace until after racing again and started experiencing rough landings. Now the old struts have no dampening on extension or compression therefore the landing is terrible. I have stood this car straight up in the pass with older struts that still had some dampening and you could not tell when the front wheels made contact with ground again. My problem exist due to laying the car up for so long. Watch car get up of shape....old struts
Bilstein will no longer re-valve one of their strut inserts to create a drag racing double adjustable strut. Koni will build one that is double adjustable and re-valve it for drag racing use. The measurements of the KONI inserts are not an exact match to the originals. The dimensions of the Koni inserts are a bit shorter than the stock and require a spacer to make up the length difference. The stroke however is the same and should be fairly easy to make work. The process of inquiring about this product was quite aggravating with both companies. I originally was quoted a price of around 800.00. I saved up the money over 3week period and called back to pull the trigger and the price changed. The final price for two struts is well into the $1000.00 Range far exceeding 100.00 per strut to re-valve. I am currently waiting for them to be built and will update with pics of installation which they arrive. I recommend asking for a quote upon inquiring about this process. Finally, I did replace my worn out struts with a new stock type pair from O’reily’s. it was a cheap $100.00 experiment. I too was convinced that a new set would slightly calm down the up portion of my launch and drastically change the landing…..It completely killed the launch!!! as it doesn’t allow the car to come up and transfer weight over the differential like it did originally. I just wanted to share my findings in hopes that it may save someone the trouble…..
Hi, I hope I am not missing a thread and this has been covered, if so please excuse. I can only find discussions about adjustable strut inserts on road racing applications. I have spoken to KONI's technical dept about revalving some for Drag Racing. They can Create one that has adjustment on both compression and extension for drag racing. I was wondering if anyone has overcame this through some other source or by having Koni custom build some similar? I know fabrication could allow for many different ways to resolve but I don't wanna cut up my stock strut assembly. Notice rebound bounce of car in video.... thanks in advance Lane
From the album: Finish Product
how much HP can a stock 240z frame take?
long240project replied to logan1's topic in Gen I & II Chevy V8 Tech Board
Logan 1 What are you primarily looking to do with the car once complete? I think it is very important to ask yourself that question with a build in order to determine direction with regards to suspension, engine components, "frame or chassis upgrades" etc. For example: I wish my car was more of a driver now that it is complete but the direction I chose engine,suspension and even fuel type wise is drag racing specific. At the end of the day I wanted to go Drag racing. That is not everyones goal. That is not to say you can't take a piece of knowledge from a drag car, a piece of knowledge from a road course car and some what arrive at a finish product that accomplishes your goal. Most people will agree that for every gain in one aspect you generally compromise in another so determining a cars primary function is key. Hope this helps a bit. -
Lets see your V8 in your Z.
long240project replied to CJBrian's topic in Gen I & II Chevy V8 Tech Board
1972 240 388cid small block
long240project replied to long240project's topic in Gen I & II Chevy V8 Tech Board
Rsicard, No problem at all. Fyi I had to order the Switch,Harness,Flasher through a Tractor/Trailer parts house that used the Grote brand. Once I received it, I extended the length of each circuit by buying strands of 16gauge wire the indentical color of each existing wire in the Grote harness and soldered and shrink wrapped it all at once. This step help to speed up the wire rough in a lot. It also made following the instruction simple. Give me a buzz if you have problems Thanks Lane -
rsicard, Switch is made by Grote. Universal turn signal switch part #48272 also buy wire harness #69680 that plugs right into it and the flasher suggested. Your turn signals are now wired with a color coded instruction sheet which is ultra straight forward and explains it word for word. Hope this helps Lane -
Sorry will take pics soon... trying to finish the car. Its driving me nutz -
All, I am searching for the center portion of the rear bumper!! I have my bumpers at a Chrome shop and he is saying that portion is twisted and unrepairable! I registered for a Big Car show in a few weeks so trying to find a good donor piece to have re-plated. Please just call me if anyone has one as I am in a time pinch! Thanks, Lane Comeaux 225-229-6094
It's a ladder bar concept, going forward from where the pic ends it attaches to floor of car by way of a flat plate with a rod end. Will take pic and post. -
Rsicard, The wiring project was kicked off a long time ago and is a done deal now. When the car was taken down I strip every single wire out of it. The car is in reality a race car so my wiring is super simple compared to trying to make every bell and whistle that it came stock with work. Will your SBC be fuel injected or Carb? You can buy an upgraded mini fuse panel that plugs right into the existing harness if you havent taken your wiring out as I did. Tell me more about the current state of the wiring and where you wanna end up and I am sure I can help. Also I will take some pics of the turn signal stalk I used!! Its super trick and super compact and has turn indicators that also light up self contained. It's hard to cover everything on here so if you are interested once i post the pics we can discuss via phone. If you want use my method. Lane -
I have to ask what is that spiffy bracket you're using for the alternator? And it looks like you're installing A/C as well? Nice! Man thanks for the compliments!! It makes the stress of the project worthwhile. The bracket is made by Moroso it comes with a Billet Aluminum finish but I had mine chromed. It must been ran with the CSR,Meziere or Moroso electric water pumps. I think it's the most trick bracket available especially if you are running old school heads like mine which do not have accessory bolt holes. Actually what you saw on my motor is a crank case vacuum pump. A/C? lol this unit is being built for wheelstands not comfort! Good news is you won't need that bracket! Here's the link to the one you would most likely be interested in. http://www.moroso.com/catalog/categorydisplay.asp?catcode=30001
