Search the Community
Showing results for tags 'cv axle conversion'.
	Running into a few issues with my halfshafts like most are. Since im running a little bit more than stock hp on my 260z, i am needing something a lot more beefy. Looking for something that can hold close to 700-800hp on an r200 diff. 29 spline Westcreek (good but is this rated for that much rwhp? read a thread where the OP ran into issues with the install.) Driveshaft shop ( Probably going with this but i hear the actual adapters rub on the control arms? is this true, will i need to notch?) Also heard you run the risk of bolts unthreading? how is this possible? z31 axles w/ adapters ( thought i would go with this route, but was pointed in the direction of CJ cave and he never replied back) Let me know your thoughts, just want to do this right and once. Without breaking the bank.... If i don't have to . Joa
- 7 replies
		- cv adapters
- cv axle conversion
					(and 3 more)
					Tagged with:
	I have come to realize that DSS stands for Drive Shit Shop not Drive Shaft Shop. I purchased their full bolt on axle kit and stub axles rated to 800 hp. Absolutely none of their "bolt on" product bolts on my Z. The adapter to diff stub axle is designed wrong and the hardware they sent will never fit....... After 3 weeks of doing my own research and sourcing my own hardware I finally came up with a solution to make the adpter work and fit albeit with ZERO input or help from DSS. Tonight, I went to test fit the new OEM bearings on the new wheel stub axles from DSS and they slop all around! The bearing surface on their stub axles measures 30mm and my stock stubs are 32mm. I am so freakin pissed right now! My car is totally torn down and nothing DSS sent me fits or is compatible with my 240Z. DSS part numbers are DAR-1 and DAR-WHEEL......... DO NOT BUY THIS CRAP! The only thing bolt on about it is that it bolts to itself beautifully. To bad it just won't bolt into a Z as advertised and the tech support doesn't know jack squat about Datsuns or its own product to help. Now I get the joy of trying to get my money back..... Oh joy! Im warning the Z community to buyer beware. This has been a terrible experience. Jim
