Search the Community
Showing results for tags 'electrical issue'.
I am not a mechanic at all, i am just a 19 yo who started liking cars and likes building things, so bear with me if some terminology or methodology is wrong Hello, I'm in a bit of a crisis with my car at the moment, and before I get told to do this, yes I have spent days searching the internet, and yes I have looked through the FSM for this model year of the 280z, and spent many days looking through the wiring diagrams trying to solve this problem. A little backstory for this project of mine: My grandpa has had this car for about 30ish years now sitting on his property. I recently took an interest in the car and was starting to get into cars in general. So he decided to let me try to restore the car with him. I should mention the car had been stripped of all components for a full restoration that 30 years ago. so I started on the car approximately 2-3 months ago now, and am almost ready to start, and paint the car, and get it road ready. Onto my electrical problems: So after I got every electrical connection together through the entire car, we plugged in a new battery to start testing the electrical components. Right off the start there were issues but not too many, the engine would crank fine but we didn't have gas so we don't know if it would have started or not. but as i have been trying to solve the problems with the electrical, i accidently shorted a ground pin to the main headlight pin in a connection while light testing and since then, the headlights don't work, and the flashers don't work. The fuses are fine none blown, and the fusible links are fine, they all get continuity & voltage through them. I have replaced the flasher relay and it didn't change anything, I have cleaned all the connections in the combination switch circuits. Then when I was testing the ignition switch, I accidently cranked the engine, and my negative to chassis ground cable instantly melted. Ever since then the positive terminal of my battery, has continuity to the chassis of the car, the engine and every single ground contact/cable throughout the car. Another thing, I'm not sure if this is normal or not, but in my fuse box, the left side of my fuel gage fuse (blue wire) has continuity with the positive terminal of my battery. Things i have tried to trace the problem so far: I have taken off all the important relays for operation and opened them, checked for any damage, and cleaned them. I have been checking all my fuses and fusible links constantly to make sure its not them. I did notice today, that when I unplug the fusible link in the picture, my positive terminal loses ground to the entire car, which has led me to believe its something to do with that cable. Any help would be apprieciated
- 2 replies
- help
- electrical issue
(and 2 more)
Tagged with:
I have a 1976 280z and I bought the car with a '82-'83 zxt engine installed in it. All wiring was taken from the zxt. I wired everything up to the swap guide I found on here. I think I have everything correct. After all the wiring, hooked up the battery terminals and after a second or two the fusible links started sparking. I unplugged the battery terminals immediately. I thought it could be the alternator so I unplugged the wires to the alternator, but still same problem. I then took a volt meter to the engine block and valve cover with the positive terminal connected to the starter and I got 12 volts on the block and everywhere else that needs to be ground. Except for the chassis. It had 0 volts. I haven't had a chance to go through all of the wiring so I was wondering if anyone could help give an idea to what it could be. Thanks
