Search the Community
Showing results for tags 'high compression'.
I am currently building my motor on my 280z, and I was looking at having the head chambers welded up. The issue I have ran into is everyone wants big money to perform this service. I was was wondering what everyone's opinion was on if should even weld the chambers, or if someone has a reasonable sou...
I am starting to plan my engine build and would like some input on my initial parts selection/configuration I am thinking. I have two N42/N42 engines to pick from. My thoughts are as follows: Block Cleaned, bored, honed, new freeze plugs, ARP main bolts, ITM flat top pistons .30" ovesize (...
- 18 replies
- n42
- flat top psiton
(and 4 more)
Tagged with:
Due to a problem with my P90 head, its getting fixed due to a bad gas incident a month ago resulting in a bent valve and leaving #5 with 0 psi on a compression test. While its there I am having the cam go through a regrind to what he thinks will be a good setup for what im looking for (mild, good st...
