Search the Community
Showing results for tags 'no start'.
  • Search By Tags
    • no start ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 4 results
  1. I have a 1978 280Z, I'm new to the Z and this platform and looking to see what direction to start diagnosing this. So i'm driving one day, and car just dies. It will turn the engine over, but won't start. it appears everything electrical if off when the key in in the "On" position. then I notic...
  2. Hello people, I have start and run issues that I believe has to do with the ignition unit, or power going to it, or some open circuit relating to that. So this was a running car untill.... I installed a turbo head and the parts needed to turbo it, along with megasquirt 2. The ms is for fuel...
  3. So im some serious needed help, i have a Neo RB25det running on the Power FC. I also am using Wiring specialties wiring harness. other than intercooler, intake-manifold, throttle body and injectors. metal head gasket and head studs. everything else is stock. I am the point of attempting to...
  4. Hey guys, been lurking/learning for a little while from old threads, thanks to all of you for all the great info I've used already. This is my first post because I can't seem to find anyone with the same problem. The car is my first Z and is a '73 240Z with a 400 sbc (stock w/ headers) and a Saginaw...
