Search the Community
Showing results for tags 'transmission swap'.
  • Search By Tags
    • transmission swap ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 4 results
  1. Hello, i want to know if its possible to fit the 300zx z31 transmission on an l28, because i have a 300zx with broken engine and an L28, i want to swap it, do i need to get a 240sx tranny? or is the 300zx going to fit somehow? Thx Guys
  2. So, I've had a couple of 4 speed housings (now a total of 4) bell housings that I need to get machined to fit specs for a S13/S14 gear box. The bell housing only changes in the main bearing size (increased), a shift rod diameter and the overall width around the face needs to be trimmed to a uniform...
  3. So i finally blew up my 2nd T5 transmission. This time locking it up solid while doing a 5th gear pull on the highway. So i figured now would be a great time to do the 240sx transmission swap I've seen from different articles. I referred alot to the following http://zhome.com/ZCMnL/tec...
  4. I have a 280Z track car with a built L28 and a 240sx trans, it has a OS Geiken LSD (not sure the gear ratios). Id like a trans with a taller first, closer second and third and a shorter fifth than the sx trans. can I get gears for the sx trans and build it? is there a trans out there that fi...
