theramz Posted May 26, 2011 Share Posted May 26, 2011 Hi guys, here is a pic of my code wheel and vr sensor mount. Quote Link to comment Share on other sites More sharing options...
akeboshi Posted June 5, 2011 Share Posted June 5, 2011 grrr, baby! very grrrr! i like this hope you dont mind if i swipe it! your engine looks immaculant btw. marcus Quote Link to comment Share on other sites More sharing options...
theramz Posted June 7, 2011 Author Share Posted June 7, 2011 I'm glad you like it. Feel free to copy it but don't ask me for dimensions, I might make more of them since I just sold the complete engine today. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted June 25, 2011 Share Posted June 25, 2011 Is that the correct location for the missing tooth @TDC or is this mockup? Quote Link to comment Share on other sites More sharing options...
theramz Posted June 27, 2011 Author Share Posted June 27, 2011 On 6/25/2011 at 6:29 PM, skirkland1980 said: Is that the correct location for the missing tooth @TDC or is this mockup? It's just a mock up. Actually I sold the engine to a guy in CA. He is putting it in a nice '73 with MS so I imagine we will be hearing from him. Quote Link to comment Share on other sites More sharing options...
jthom5147 Posted June 29, 2011 Share Posted June 29, 2011 On 6/27/2011 at 1:24 PM, theramz said: It's just a mock up. Actually I sold the engine to a guy in CA. He is putting it in a nice '73 with MS so I imagine we will be hearing from him. The engine is very clean as someone else said. I purchased some of the other components I know I will be needing for my swap and when I'm closer to starting work, I'll start a build thread. Right now I'm also making sure I have an accurate and complete wiring diagram to follow. --James Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted June 29, 2011 Share Posted June 29, 2011 Thanks. I'm doing this upgrade for my MS eventually and am a little confused on where the gap goes. DIY says 6 teeth ahead of the sensor, but does that mean 6 teeth before TDC? Quote Link to comment Share on other sites More sharing options...
jthom5147 Posted June 29, 2011 Share Posted June 29, 2011 (edited) On 6/29/2011 at 12:10 PM, skirkland1980 said: Thanks. I'm doing this upgrade for my MS eventually and am a little confused on where the gap goes. DIY says 6 teeth ahead of the sensor, but does that mean 6 teeth before TDC? In short, no. <a href='http://www.megamanual.com/ms2/EDIS.htm'>http://www.megamanual.com/ms2/EDIS.htm</a> said: The VR sensor and 36-1 crank trigger wheel must be set in the correct relationship to each other. With the engine at TDC for cylinder #1, this relationship is: EDIS-4: missing tooth is exactly nine teeth (90°) ahead of the VR sensor, EDIS-6: missing tooth is exactly six teeth (60°) ahead of the VR sensor, EDIS-8: missing tooth is exactly five teeth (50°) ahead of the VR sensor. Note that you have a choice where to place the sensor, IF you can shift the wheel. It is a good idea to build the VR sensor bracket so that you have a degree of radial adjustment (closer/farther from the wheel) and angular adjustment (closer/further from TDC). Also, bear in mind that most automotive engines rotate clockwise when viewed from the front, except many Honda engines. Source: http://www.megamanual.com/ms2/EDIS.htm The edis-6 needs the 60 degrees. The 60 degrees between the missing tooth and vr sensor can be positioned anywhere around the toothed wheel edge, so long as the 60 degrees are set in the correct relationship with the engine using engine TDC as a reference point. I hope that is more clear. Edited June 29, 2011 by jthom5147 Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 7, 2011 Share Posted July 7, 2011 On 6/29/2011 at 3:30 PM, jthom5147 said: In short, no. Source: http://www.megamanual.com/ms2/EDIS.htm The edis-6 needs the 60 degrees. The 60 degrees between the missing tooth and vr sensor can be positioned anywhere around the toothed wheel edge, so long as the 60 degrees are set in the correct relationship with the engine using engine TDC as a reference point. I hope that is more clear. yes thank you Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 7, 2011 Share Posted July 7, 2011 so the photo is about right then? Quote Link to comment Share on other sites More sharing options...
jthom5147 Posted July 8, 2011 Share Posted July 8, 2011 (edited) As for their relationship in general, no, the mock-up depicted in the picture is not accurate. The missing tooth is "behind" the vr sensor in the pic. Since the rotation of the engine is clockwise the missing tooth needs to be 60 degree more clockwise than the vr sensor. I.e. if the crank pulley is a clock face, the vr sensor is at 12, missing tooth is at 2, so long as the engine is at TDC (or whatever number for the vr sensor you wish, and n+2 for the missing tooth). Edited July 8, 2011 by jthom5147 Quote Link to comment Share on other sites More sharing options...
theramz Posted July 11, 2011 Author Share Posted July 11, 2011 Hi James! Glad you are getting it going. Looking forward to your build thread! Tom Quote Link to comment Share on other sites More sharing options...
SHADY280 Posted July 12, 2011 Share Posted July 12, 2011 with this setup can you have all accesories??? i like my power steering and a/c. so far thats been what holding me back from going this route. Quote Link to comment Share on other sites More sharing options...
theramz Posted July 12, 2011 Author Share Posted July 12, 2011 On 7/12/2011 at 2:26 PM, SHADY280 said: with this setup can you have all accesories??? i like my power steering and a/c. so far thats been what holding me back from going this route. AC yes ps no. I made this for my S30. We have to muscle our cars around but AC is a must. A larger diameter code wheel and different adaptor hub might allow for the ps pulley. I spaced it out away from the damper to avoid any possible feedback. In fact the stock fan won't quite clear. James said he will be using electric fans. Quote Link to comment Share on other sites More sharing options...
jthom5147 Posted July 13, 2011 Share Posted July 13, 2011 On 7/12/2011 at 7:15 PM, theramz said: AC yes ps no. I made this for my S30. We have to muscle our cars around but AC is a must. A larger diameter code wheel and different adaptor hub might allow for the ps pulley. I spaced it out away from the damper to avoid any possible feedback. In fact the stock fan won't quite clear. James said he will be using electric fans. 4 row alum radiator with alum shroud and dual electric fans! The stock intake side and AC bracket bolts are unhindered by Tom's setup. I'm not so sure about the PS (none of the s30's i work on have had it installed). Quote Link to comment Share on other sites More sharing options...
jacob80 Posted July 29, 2011 Share Posted July 29, 2011 A little off topic but... I want one of your brackets! Will you be producing anymore? Let me know. Thanks! Quote Link to comment Share on other sites More sharing options...
theramz Posted July 29, 2011 Author Share Posted July 29, 2011 On 7/29/2011 at 3:34 PM, jacob80 said: A little off topic but... I want one of your brackets! Will you be producing anymore? Let me know. Thanks! I can make more so pm me, Tom Quote Link to comment Share on other sites More sharing options...
