joker120 Posted June 16, 2011 Share Posted June 16, 2011 As you all know I was having quite a time with the damn harness on my 78. The injectores are firing, it's in time and I have spark... Now the question, Is there a small cap on the end of these injectors that has some function? Mine have deteriorated and the injector will deliver fuel when the needle houseing is depressed and the engine will fire when I throw gas into the head so any idea guys? Is it these simple caps? Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 17, 2011 Share Posted June 17, 2011 You must be talking about the pintle caps. The general word seems to be that they don't significantly affect anything if broken. Broken caps certainly wouldn't keep the injectors from injecting. If the injectors have fuel pressure and they are energizing then fuel has to enter the head. Are you sure that the injectors are firing? People have been known to remove them, attach them to the fuel rail and place them in to containers, then crank the engine to verify fuel flow. It takes some work but if the engine runs with fuel added through a vacuum port or the throttle body then lack of fuel through the injectors is the obvious place to look. You can also turn the key to On, connect a jumper wire to the coil (-) and tap it to ground to hear the injectors fire. Credit to Tony D for describing the method, the basics of why are described in the FSM. Basically you're telling the ECU that the coil has fired three times and the engine has made one revolution. I just tried it to be sure it works. Three sharp taps to ground and you can hear the injector solenoids. I have a 76 but the electronics are essentially the same as your 78. The wire from coil (-) to the ECU Pin 1 runs through the tach by the way. So the 280Zs won't run without the tach installed. Quote Link to comment Share on other sites More sharing options...
joker120 Posted June 17, 2011 Author Share Posted June 17, 2011 Thanks bud, it just looks like a jumbled mess under there to me, much the same as you guys looking at my dumb posts:lol Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 17, 2011 Share Posted June 17, 2011 No problem bud. Not sure what you mean by "under there" though. Make sure that your injectors are actually opening when the engine is turning over. Good luck. Quote Link to comment Share on other sites More sharing options...
KillerBjt Posted June 17, 2011 Share Posted June 17, 2011 Couldn't it also be that the injectors are firing but are clogged/bad spray pattern? Quote Link to comment Share on other sites More sharing options...
joker120 Posted June 18, 2011 Author Share Posted June 18, 2011 No there's plenty of fuel coming through them but I'm getting zero pressure on the return? I'm heading back into the shop in a bit after more reading on these things Quote Link to comment Share on other sites More sharing options...
joker120 Posted June 18, 2011 Author Share Posted June 18, 2011 On 6/17/2011 at 2:20 AM, NewZed said: You must be talking about the pintle caps. The general word seems to be that they don't significantly affect anything if broken. Broken caps certainly wouldn't keep the injectors from injecting. If the injectors have fuel pressure and they are energizing then fuel has to enter the head. Are you sure that the injectors are firing? People have been known to remove them, attach them to the fuel rail and place them in to containers, then crank the engine to verify fuel flow. It takes some work but if the engine runs with fuel added through a vacuum port or the throttle body then lack of fuel through the injectors is the obvious place to look. You can also turn the key to On, connect a jumper wire to the coil (-) and tap it to ground to hear the injectors fire. Credit to Tony D for describing the method, the basics of why are described in the FSM. Basically you're telling the ECU that the coil has fired three times and the engine has made one revolution. I just tried it to be sure it works. Three sharp taps to ground and you can hear the injector solenoids. I have a 76 but the electronics are essentially the same as your 78. The wire from coil (-) to the ECU Pin 1 runs through the tach by the way. So the 280Zs won't run without the tach installed. this is what I've done so far, pulled the rail and injectors but they have power and just arent pulsing open best I figure.... I was going to jump off the + of the battery since it's right there unless the current isn't stepped down before the injectors... Quote Link to comment Share on other sites More sharing options...
joker120 Posted June 18, 2011 Author Share Posted June 18, 2011 On 6/17/2011 at 3:37 PM, NewZed said: No problem bud. Not sure what you mean by "under there" though. Make sure that your injectors are actually opening when the engine is turning over. Good luck. The jumbled mess down there refers to this rail and injectors that are kinda a pain to get at lmao Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 18, 2011 Share Posted June 18, 2011 The injectors are opened by the ECU grounding the circuit to energize the injector solenoids. The injectors will always have power when the key is at On or Start. If you have power at the injectors then you need to look at the grounding circuit. The ECU gets it signal from a wire that runs from coil (-), through the tachometer and to Pin 1 at the ECU. Check continuity from coil (-) to Pin 1 at the ECU plug. The tachometer needs to be installed for your car to run. Quote Link to comment Share on other sites More sharing options...
joker120 Posted June 18, 2011 Author Share Posted June 18, 2011 Its installed, running that diagnostic now, thanks brother this fuel injection is giving me fits and I wanna drive her! Quote Link to comment Share on other sites More sharing options...
joker120 Posted June 18, 2011 Author Share Posted June 18, 2011 Funny thing is I hear the injectors cyclIng Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 18, 2011 Share Posted June 18, 2011 On 6/18/2011 at 6:09 PM, joker120 said: Funny thing is I hear the injectors cyclIng You can hear them when the engine is turning over when you try to start it? They only cycle once per each engine revolution when the engine is turning over and the coil is firing. You might be hearing rocker/valve noise, it would be hard to distinguish injectors from all of the other noise with the starter engaged. Try grounding the coil (-) with the key On. The only noise then will be the snap of the spark when you tap to ground and the injectors all energizing every third tap. Or the screwdriver from injector to ear method while cranking the engine. Quote Link to comment Share on other sites More sharing options...
joker120 Posted June 18, 2011 Author Share Posted June 18, 2011 Holding the injector to my ear I can hear it hitting, it's just delivering fuel until manually depressed Quote Link to comment Share on other sites More sharing options...
