1973 240z rear lights layout
Is your car running? or lights working?
Why don't you have someone step on the brakes, BOoya, that's the brake light.
Put in reverse, Booya, that's reverse. Turn on the blinkers, booya.
Process of elimination. Reverse should go in the slot that has a clear lense, and most likely is a clear bulb.
so you got 1 of three. That's only 2 left. 50/50 you get it right or wrong from here.
Here is everything you need. If you can't find it here, come back and I can help you.
http://www.atlanticz.ca/zclub/techtips/electrical.htm
Edited by Ducer
