3.1L stroker
Let me rephrase that, I have all the bottom end ready, I'm going with a performance cam (.460 lift and 270/280 in/ex), o.e.r sport injection, 6-1 header, Stock valves (n42 head), centerforce clutch II, Kameari 2mm metal head gasket, and a 10.8 lb flywheel. any improvements I can do?
  • 3 weeks later...
Doing a EFI 3.1L turbo should be up and running in a week or so... But ive said that for months now.
* F54 L28et turbo block
* JE Forged Pistons and rings 89mm
* Mechart A-Beam Investment casted Stainless Steel rods
* ARP Rod Bolts
* Diesel Maxima Crank shaft Knife edged lightened and Zero balanced
* Nismo oil pump
* ARP Head studs
* SCE 2mm Solid Copper head gasket with sealing rings
* Nismo single groove dampener w/ Nismo front crank bolt
* 83 zx turbo oil pan
* P90 Head
* Schnider Cam Lift(In/Ex): .460/.460. Duration(In/Ex): 270/280.
* Schnider matching dual valve springs, retainers, lash pads, and rocker arms
* Ported polished
* 5 angle valve job
* Resurfaced and decked combustion chamber and intake/exhaust side
* N42 non-egr intake manifold
* 420cc injectors (merc)
* JSK Fuel rail w/ Autometer pressure gauge
* T3/T4 Turbo
* MSA Down Pipe
* Oil pressure T-fitting w/ Hard style oil to turbo
* zx turbo valve cover
* 83 280zx electronic distributor
* 2.5" thick innercooler
* Borg Warner T-5
* zero balanced flywheel and clutch
* 3 core MSA radiator
* Walbro 255lph fuel pump
* MSnS V2.2
* MS Relay board
* MS Boost Controller
* Fuel regulator
* MSA BOV
I thinks that all i can remember off the top of my head. if you want to see some pics look up L31ET
Eventually going with 750cc injectors, bigger CAM, and ITB system.
