michaelp Posted August 15, 2011 Share Posted August 15, 2011 I'm looking to build a carb'd LT1, and I searched and searched but find mixed results. I know about the GMPP intake manifold, but have found some people saying Vortec intake manifolds will bolt up and work even though they're only 8 bolt, instead of 12...and others say they don't work. Has anyone actually done this or is it hearsay? Thanks! Quote Link to comment Share on other sites More sharing options...
Mike C Posted August 20, 2011 Share Posted August 20, 2011 I have the GMPP intake although I have not actually bolted it on the motor yet... But just knowing that the biggest issue the Vortec motors had was the intake gaskets failed, I wouldn't consider running one if it did bolt up. As usual, YMMV. Quote Link to comment Share on other sites More sharing options...
rsicard Posted August 22, 2011 Share Posted August 22, 2011 michaelp: It seems the older style 12 bolt intake manifolds may work. The LT-1 cylinder head does not have coolant ports to the intake manifold but that should not be a problem. Suggest trying a dry fit of an older style intake manifold to see if the LT-1 water pump can be retained and not interfere with the older intake manifold. The other concern may be the steam ports/hoses at the rear of the LT-1 cylinder heads keeping them intact. Interested to know how this works out. Quote Link to comment Share on other sites More sharing options...
