disabling the injector cutoff and high idle?
midnightcarving
High Idle, search for BCDD. It can be tweaked.
Fuel cut on decel, is built into the electronics of the ECU. It can have a lobotomy if you are good with electronics. Look for a thread on here about the factory fuel injection, started by BRAAP I think.
why remove the fuel cut? It only operates on decel, and without it your fuel mileage will be cut to about 65-75% of what it currently is, along with pumping out so much hydrocarbon residue you could light the exhaust and support a flame...
If you think the exhaust stinks now, remove fuel cut on decel!
:huh:
