Rb25det starter
David GArcia
I've been trying to follow this writeup but, I cannot find were to connect the starter wire. I have spliced both the yellow and the black and white wire together but I don't know where to plug the wire itself into. Any help please?
This is the plug;
RBZwire015.jpgthe picture is from chris rummel
As you can see the yellow and white black wire are spliced but where does the plug connect to?
Edited by David GArcia
The plugs at the rb25det transmission were ripped of by the previous owner so i have no neutral switch plug nor the reverse light plug. I had to splice both of the nutral switch leads together to make a neutral connection at all times. Only then was i able to turn over my car. :D
