Advice on getting driveshaft off 75 z?
dpuma8
I have looked online a bit and I can't get a straight answer as to how to get the 4 bolts loose. What size wrench do you use and how did you hold the nut in the back? I don't have any room to get to the back.
Any advice on how to get into these tight spots?
I took mine off with 2 12mm or 14mm box end wrenches. You will need to put the rear wheels up, and take it out of gear to turn the driveshaft and loosen one or to bolts at a time. Each time pulling the handbrake to keep it from turning. I was able to get the bolts off and on without removing the sway bar
I can't remember if the bolt head is already locked by the flange, but if it isn't, I would just jam a flat screwdriver blade in to lock it. That cuts the wrench problem by half, just be sure to put the blade in from the side so that turning the nut pulls the screwdriver in, not pushes it out. On my S13 they were 'locking head' bolts, guess I should grab some next time I'm at the U-Pull and see if they work on the S30 too.
