Fuel injectors
RB240zDET
I've used both on my stock 76 L28. But the FPR is different between 76 and 78 so you'll need the proper year FPR, or aftermarket FPR, and/or to do some fuel line plumbing modification. 76 had two inlets to the FPR, 78 has one. The cold start valve line is a hard line on 78 and rubber hose on 76 also, but they go to the same spot. The mounting brackets, and inlet/outlet lines start/end at the same spot.
Edited by NewZed
