RB240zDET Posted September 26, 2011 Share Posted September 26, 2011 I need an entire fuel rail with injectors for a 78 280z l28 engine ASAP. Can paypal tonight if you have a full set working properly. Thanks guys. Quote Link to comment Share on other sites More sharing options...
R3VO 3VOM Posted September 28, 2011 Share Posted September 28, 2011 Will injectors and rail from a 76 280 work? Quote Link to comment Share on other sites More sharing options...
RB240zDET Posted September 28, 2011 Author Share Posted September 28, 2011 Will injectors and rail from a 76 280 work? Idk, they should I would assume. Seeing as the engine is still a l28...Let me find out. Quote Link to comment Share on other sites More sharing options...
NewZed Posted September 28, 2011 Share Posted September 28, 2011 (edited) I've used both on my stock 76 L28. But the FPR is different between 76 and 78 so you'll need the proper year FPR, or aftermarket FPR, and/or to do some fuel line plumbing modification. 76 had two inlets to the FPR, 78 has one. The cold start valve line is a hard line on 78 and rubber hose on 76 also, but they go to the same spot. The mounting brackets, and inlet/outlet lines start/end at the same spot. Edited September 28, 2011 by NewZed Quote Link to comment Share on other sites More sharing options...
