Drive Shaft Question
rsicard
This question is for John Coffey or Mr Mortenson, concerning the alignment of the Drive Shaft in relation to both the third member and tailshaft of the transmission, if there is other than 3 degree opposite angles on each, can a CV joint at say the differential end of the shaft solve any potential vibration problems? Would like to know first hand experiences concerning this alignment issue. Thanks.
  • 3 weeks later...
I think it's a bad idea to run only one u-joint. You will get more vibration. U-joints are always used in pairs to help cancel out vibration caused their inherent non-constant velocity. Two CV joints would definitely smooth out the drive train and allow greater angular misalignment but it comes at a weight penalty.
Edited by rossman
