Lukaniuk Posted October 7, 2011 Share Posted October 7, 2011 I've just picked up a diff from a 91 Q45. This is my first experience with a LSD and I'm a little concerned about it: 1) Turning on either output takes a lot of force. I can do it by hand, but it is tough. A lot tougher than any of the open diff's seen - is this normal? 2) Looking at the diff it doesn't look like the drain or fill plugs, or any of the bolts on the cover have seen a wrench in years. When I opened the cover there was hardly any fluid. Nothing looks irregular inside (I think), but I'm worried that this thing is toast. Is there anything I can do to give it a more thourough inspection? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 7, 2011 Share Posted October 7, 2011 (edited) When you turn the side gears in opposite directions, you're forcing them through the viscous fluid which is what makes the LSD work. It should feel difficult to turn. If you turn the pinion and it is hard to turn, then you may have a problem. You could pull the main caps off and remove the carrier and look at the bearings, but make sure you mark left and right and top and bottom and put the shims back in correctly. If the pinion moves smoothly I'd just install it and go for a test drive and see what it feels/sounds like. Edited October 7, 2011 by JMortensen Quote Link to comment Share on other sites More sharing options...
Lukaniuk Posted October 7, 2011 Author Share Posted October 7, 2011 When you turn the side gears in opposite directions, you're forcing them through the viscous fluid which is what makes the LSD work. It should feel difficult to turn. If you turn the pinion and it is hard to turn, then you may have a problem. You could pull the main caps off and remove the carrier and look at the bearings, but make sure you mark left and right and top and bottom and put the shims back in correctly. If the pinion moves smoothly I'd just install it and go for a test drive and see what it feels/sounds like. Thanks. If I'm only turning 1 side gear does the diff act the same as if I'm turning both of them in opposite directions? Unless I'm missing something, it makes sense in my head that it would, and the pinion does move smoothly. Quote Link to comment Share on other sites More sharing options...
