michaelp Posted October 26, 2011 Share Posted October 26, 2011 I've searched and searched, and find mixed results. I'm looking for someone who may know if a 280Z distributor (non points) with the mechanical advanced welded so it doesn't move can be used as a trigger in MS2 or 3? I'd love to run MS2 or 3 with DIS (either coil on plug or coil packs), but I'm looking for a trigger source for crank position without using a 280ZX turbo dizzy. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 26, 2011 Share Posted October 26, 2011 (edited) It can be used for "Basic Trigger" (simple distributor) mode. Edited October 26, 2011 by Matt Cramer Quote Link to comment Share on other sites More sharing options...
michaelp Posted October 26, 2011 Author Share Posted October 26, 2011 On 10/26/2011 at 8:20 PM, Matt Cramer said: It can be used for "Basic Trigger" (simple distributor) mode. And that will be adequate for batch fuel control and DIS ignition control? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 27, 2011 Share Posted October 27, 2011 On 10/26/2011 at 8:25 PM, michaelp said: And that will be adequate for batch fuel control and DIS ignition control? Batch fuel control yes, DIS ignitions, no. There's no way to tell the teeth on the rotor apart. Quote Link to comment Share on other sites More sharing options...
Nhuwar Posted November 30, 2011 Share Posted November 30, 2011 What if you use a missing tooth crank trigger wheel with a hall effect sensor? And also would it work with the ms3x? Thanks, Nick Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted November 30, 2011 Share Posted November 30, 2011 A hall effect sensor only picks up a magnet, permanent or electro-. You need a proximity sensor (metal detector) to operate a missing tooth crank wheel. Quote Link to comment Share on other sites More sharing options...
Nhuwar Posted November 30, 2011 Share Posted November 30, 2011 (edited) Ops Brain fart. Has anyone done this though? Use a crank trigger wheel on a l28 that is? Nick Edited November 30, 2011 by Nhuwar Quote Link to comment Share on other sites More sharing options...
