emeraldlion Posted October 29, 2011 Share Posted October 29, 2011 Yeah, this may be a moment of stupidity, but when I first started pulling stuff I threw out the ignition box that mounts in the passenger footwell. Not sure why. Am I actually going to need that when I start wiring up? The JTR manual states you only need to wires going into the box, but does that mean you need the box to be there and plugged in? If so, anyone got a spare? Quote Link to comment Share on other sites More sharing options...
redbaron Posted October 29, 2011 Share Posted October 29, 2011 Yeah, this may be a moment of stupidity, but when I first started pulling stuff I threw out the ignition box that mounts in the passenger footwell. Not sure why. Am I actually going to need that when I start wiring up? The JTR manual states you only need to wires going into the box, but does that mean you need the box to be there and plugged in? If so, anyone got a spare? If your doing a V8 swap you don't need it. You will be using the ignition module thats on the V8 Quote Link to comment Share on other sites More sharing options...
emeraldlion Posted October 29, 2011 Author Share Posted October 29, 2011 Unless it's a carb'd swap and has no ignition module? Just wiring straight to the HEI Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 29, 2011 Share Posted October 29, 2011 I have a 76 with a GM HEI module. The stock ignition module is completely disconnected and everything works fine - tachometer, ECU, etc. It won't be needed if you're using a different ignition system. It's apparent from the wiring diagrams also, if you want to be positive. Quote Link to comment Share on other sites More sharing options...
emeraldlion Posted October 30, 2011 Author Share Posted October 30, 2011 Excellent, I appreciate the post. For some reason I was drawing a blank here. Quote Link to comment Share on other sites More sharing options...
