ComicArtist Posted November 2, 2011 Share Posted November 2, 2011 Just noticed on their camber plates that there is no upper perch for the top of the spring to rest against. All there is is the gold slider part to adjust the camber. ....so what're you guys running for your coilovers? It's apparently not as simple as taking off the tophat, sticking the piston through the hole and securing the nut on top. There's gotta be something for the spring to rest against. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted November 3, 2011 Share Posted November 3, 2011 (edited) In the description for the camber plates on TTT website..... We also have full upper hat systems for use with 2.5" coilovers. The upper hat setups include machined upper hats, hardened washers and the Torrington Needle bearings. Cost on the upper hat systems is $50.00 per Pair http://technotoytuning.com/productdetail.php?p=648 Edited November 3, 2011 by 280zcar Quote Link to comment Share on other sites More sharing options...
mistah mofro Posted November 5, 2011 Share Posted November 5, 2011 ^what he said Quote Link to comment Share on other sites More sharing options...
ComicArtist Posted November 8, 2011 Author Share Posted November 8, 2011 Ran into another problem. Just got my plates in and the hole in the pillowball for the strut to go through is considerably bigger than my strut piston. Seems like if I bolt it up, there will be considerable side-to-side play in the pillowball. Should I find a solid bushings or something to make it fit as tight as possible? There's gotta be people on here who have had that problem. Quote Link to comment Share on other sites More sharing options...
ComicArtist Posted November 8, 2011 Author Share Posted November 8, 2011 After looking at their product picture again, I think I'm missing something. The top picture here are mine. You can see how big the pillowball bearing is, a good 3/4". In their product picture, it looks like there's some type of bushing insert in their pillowballs, reducing the size of the hole greatly. Any info as to what they are? Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted November 8, 2011 Share Posted November 8, 2011 I'd consult the person you purchased them from (or perhaps Techno toy tuning). The previous person obviously made his own modifications with making them bolt-on instead of welded in. Even if there is a bushing/sleeve missing, you have integra shocks if I remember correctly, which have an even smaller diameter than stock style S30 shocks.... Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted November 9, 2011 Share Posted November 9, 2011 Different brands of struts have different size shafts. You need that part of the camber plate to be matched to your struts. Measure the inside of the bearing with a vanier caliper, and make sure it matches the diameter of your strut rod. If it is imcompatable, talk to JohnC to see what type of strut to buy to go with those. You got domino's disease. Quote Link to comment Share on other sites More sharing options...
diz9 Posted November 9, 2011 Share Posted November 9, 2011 I have bought same camber plates and T3 supply to me the good spacers (the one you can see on the T3 website picture) to fit with my strut I don't know about the price Quote Link to comment Share on other sites More sharing options...
ComicArtist Posted November 9, 2011 Author Share Posted November 9, 2011 Called Gabriel at T3 last night and figured out what I needed. Apparently there's a needle bearing, two washers, and four bushings that you need sized exactly to your shock shaft to install them. I didn't know this since I bought my camber plates secondhand. Probably would've been easier to just order them from T3 in the first place, but it was too good of a deal to pass up. Quote Link to comment Share on other sites More sharing options...
