78 280z Project
First post...Just Picked up a 1978 280Z....Think its an original Black Pearl.
From what I have read it has the correct color code number 638.
Not sure if that makes the car any more valuable.?
I have been wanting a S30 Z car for 5 or so years and finally got a chance.
Found her on CL has 150K. 99% all original. Not too much under the hood or anywhere else
has been messed with or modified and all the parts are there. (which is what I liked about the car)
Payed right at a grand for the car. It runs and drives. has only a few rust areas/dents.
It had not been driven on the road for 2 years stored outside so I got to work on it right away.
Started by pulling the seats/carpet and deadening material. (which is quite a chore)
Edited by 78ZDude
First weeks update...
Fully stripped the Front floor pans, factory deadener removed, used aircraft stripper for the paint W/ wire wheel attached to angle grinder. Patched over holes with sheet metal. Fully welded very thin section in front of passenger side seat was double layer for strength. Only hole that was a concern was in passenger side foot well.
Golf ball size. Made patch more than double the size of hole to disperse the load and to weld to solid metal.
ground the welds down a little (wasn't looking for perfection since it will be covered up anyways.)
2 Coats of POR15 and 1 thick coat of herculiner bed liner sprayed with a bed liner gun later..
Pretty sure it will never ever rust again. Love the way the bed liner makes it look and gives it extra sound and heat blocking. I am planning on keeping it like this until I get other things sorted and get around to buying carpet.
Next I will probably tackle the hesitation/sputter when I try accelerate hard.
Dist Cap and rotor look like original as do the Plug wires, Going to do a full Tune up first to get me started.
Has had a new fuel pump install by the PO. But will not rule that out if it doesn't run better after tune up.
Need to get a Service manual for the car as the haynes book that came with it is about useless.
Edited by 78ZDude
