Clutch Goes straight to floor
Hey guys today i had trouble getting my car into gear after turning it on, and my clutch pedal seemed to go straight to the floor. i pumped it a few times and was finally able to put it into gear. But about 5 min ago i tried the same trick and just didnt seem to work it went straight to the floor i was out pumpin it for a couple minutes and finally gave up. Possible problems air in clutch master cylinder? Help on what and where to check thank you.
Same thing happened to me it was my master cylinder for the clutch check if there is fluid on your firewall under the dash. Also you might want to check your slave cylinder on the tranny
the master cylinder for brakes and clutch is the same one correct. and there is some but only because i spilled a bit when filling up the resevoirs but prior to that it was dry.
and where can i find the slave cylinder on the trans?
  • 1 month later...
