Dadaluma Posted January 9, 2012 Share Posted January 9, 2012 I Had a question, I added the 1kohm 1/4 watt resistor inline with wire from pin 24 and 12v+, per mobys writeup on diyautotune, I tapped into the 12v source for my wideband could this cause any problems because, my afr #'s dont seem right at idle 9-10. just a thought, really trying to get this thing to run right:banghead: thank again. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted January 9, 2012 Share Posted January 9, 2012 That shouldn't be an issue; what wideband are you running? Quote Link to comment Share on other sites More sharing options...
Dadaluma Posted January 9, 2012 Author Share Posted January 9, 2012 innnovate Lc1 Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted January 10, 2012 Share Posted January 10, 2012 Did you configure the lc-1's output? Are there any exhaust leaks? Did you calibrate the sensor in free air? Quote Link to comment Share on other sites More sharing options...
Dadaluma Posted January 11, 2012 Author Share Posted January 11, 2012 no known leaks, but i got most of my problems sorted now thanks. cured disconnects with new different serial adapter and scaled down ve table for about 13:1. one problem i dicovered was #4 cyl. the injector o-ring was not fully seated fixing that now. thanks Quote Link to comment Share on other sites More sharing options...
