laxz6 Posted January 12, 2012 Share Posted January 12, 2012 Hey so first off I tried the search button but no luck. My 1977 280z engine is all stock just changed the essential parts. When I first start It, It starts right up and runs like a champ, but when It's fully up to temperature and has been running for 30 min straight, I can't step on the gas hard on 3rd or 4th because It doesn't accelerate, It like bogs down. I have to step on the gas slowly so it won't feel like If It turns off. I changed the fuel filter, air filter cleaned the gas tank, but no luck. I really need help because It's my daily driver and I don't have the money to buy another car. Any help would be appreciated, thanks. Link to comment Share on other sites More sharing options...
Rome Posted January 12, 2012 Share Posted January 12, 2012 Carb'd? or fuel injected? Link to comment Share on other sites More sharing options...
laxz6 Posted January 12, 2012 Author Share Posted January 12, 2012 It's fuel injected. Brand new injectors also. Link to comment Share on other sites More sharing options...
Rome Posted January 12, 2012 Share Posted January 12, 2012 How about a going bad tps? That happend to a buddys z one time. Ran fine for about 20mins then leaned out and ran funky.. Link to comment Share on other sites More sharing options...
laxz6 Posted January 12, 2012 Author Share Posted January 12, 2012 Do you know how to check if it works or not? I'll keep that in mind when I go to the junk yard. Thanks anyways. Link to comment Share on other sites More sharing options...
NewZed Posted January 12, 2012 Share Posted January 12, 2012 Freeeee!!!! http://www.xenons30.com/reference.html You can't go wrong by reading the Engine Fuel section. I've seen a fuel pump look great (watching a fuel pressure gauge) for about 20 minutes, then slowly lose pressure. Might be worth borrowing a pressure gauge and strapping it in the engine bay while you go for a drive. Stop and take a look when the problem happens or attach it where you can see it while driving. Link to comment Share on other sites More sharing options...
laxz6 Posted January 12, 2012 Author Share Posted January 12, 2012 Thanks for the help, ill try that this weekend. It does make sense, a 35 year old car with the original fuel pump, might be time to change it. Thanks for the help. Link to comment Share on other sites More sharing options...
surpip Posted January 12, 2012 Share Posted January 12, 2012 Could be a coolant temp sensor as well, or the ignition module starting to act up due to dryed out grease. Link to comment Share on other sites More sharing options...
laxz6 Posted January 14, 2012 Author Share Posted January 14, 2012 Could be a coolant temp sensor as well, or the ignition module starting to act up due to dryed out grease. Im not sure that it might be the coolant temp because it read the temp correctly. Well if it were to be the ignition module that would act up, it would not fire correctly Im assuming. Link to comment Share on other sites More sharing options...
surpip Posted January 14, 2012 Share Posted January 14, 2012 There are 2 different sensors for the ECT one each for gauge and ECU and the modules are fairly intermittent but can throw you for a loop. Link to comment Share on other sites More sharing options...
laxz6 Posted January 14, 2012 Author Share Posted January 14, 2012 There are 2 different sensors for the ECT one each for gauge and ECU and the modules are fairly intermittent but can throw you for a loop. Alright thanks, i always learn new thing on this forum. Thanks Link to comment Share on other sites More sharing options...
surpip Posted January 14, 2012 Share Posted January 14, 2012 Be shure to let us know what you find good luck! Link to comment Share on other sites More sharing options...
